N5IMS: GREAT INFO
Tell me, what freqs should I have loaded for my drive Alliance Corridor to Denton, and also for Denton to Highland Village to FM to Grapevine, and reverse.
Those "zones" represent 98% of my life.
THANK YOU
This page (
Metrocrest Amateur Radio Society) has links to the Chirp software (the gold standard for ham radio programming) and a .csv file used by the MARS club's ARES/RACES organization as their "standard load". The first few items are MARS specific and has their repeaters as well as a simplex backup used for ARES/RACES nets. The repeaters are duplicated further down the list as well. This is because the basic load is used by several ARES/RACES groups in the area where the basic list is identical but those first few lines are for easy access to that group's repeaters while the rest of the list are the same. This allows quick and easy access to that group's frequencies while allowing easy and correct programming for repeaters that may be used during large emergencies.
A more complete list (well, a couple of lists) can be found here
Dallas / Fort Worth Repeaters and Ham Radio by N5LXI / joel Sampson Art - Dallas Texas
If you would rather roll your own, these are some good choices:
City, Freq, Offset, PL
Denton, 146.92, -, 110.9
FT. Worth, 146.94, -, 110.9
Arlington, 147.14, +, 110.9
Carrollton *, 145.21, -, 110.9
Lewisville, 145.17, -, 110.9
Plano, 147.18, +, 107.2
Dallas, 146.88, -, 110.9
Due to work being done on the normal site, 145.21 is using their back-up site with a reduced footprint. Once the regular site is again available (at this point it's past due, but what government project is ever on time - did I really say that???) it will return to the wide-area footprint.
Using the MARS and N5LXI lists you can make a pretty complete list when combined with mine above. Be aware that since most of those lists were created, several repeaters have upgraded to Yaesu Fusion repeaters, but most of those are in "Auto" mode where they will be in standard analog mode if it hears an analog signal but may be in digital mode if only digital users are transmitting. There are also some other digital repeaters in the area (like DStar, P-25, MotoTRBO, etc.) so you may hear some digital "noise". Some are like the Fusion ones and will revert to analog for analog signals or use digital when digital signals are in use. For most dual-mode repeaters, you can avoid the digital "noise" by programming in a receive CTCSS tone for the repeater. Digital modes don't use a tone so this will only open the squelch when in normal analog mode.
Just remember that some repeaters that may appear close have rather small coverage areas and others that may be far away (based on their reported location anyway) have great coverage. You may want to program in most on the lists and let the coverage work themselves out. If the coverage is small scanning will jump over them quickly and if they're noisy and you never appear in their range, just lock out that channel for scanning.
