Tdenfuny, a great question.
How you ground your equipment depends on what you want the ground to do, You are correct- if it is RF alone that you are looking for in a "ground," the countepoise of a dipole's element or the matrix beneath a vertical will provide that "ground'-- ie: the RF return. For an example; all you have to do is look at a 440 handheld- the 'ground' is capacitvely coupled from your body to the unit's chassis.
The "ground" you have in question, that terminal on the back of the radio and its power supply is there for another reason. I provides a direct ground return in the event the radio chassis goes high with respect to the AC power line. Any number of things can cause that, but it provides a direct ground thru that 'green wire'- instead of you- into the earth. Just like a hair dryer (sexist
,) that short'd circuit to the chassis will blow a Ground Fault Circuit Interrupter (GFCI)- hopefully (you have one, No?
) instead of electrocuting you-- should your body complete the ground circuit. Remember, your AC service has a ground return connect'd already (its the white wire, the 'common')- you do not want to be the substitute part of it !..... That chassis terminal also provides a dump for any static charges that accumulate on the equipment- but do not mistake it for anything lightning related-- if a lightning spike has made it that far into your equipment, everything is now toast.
This is my favorite guide to grounding:
http://lightningsafety.com/nlsi_lhm/IEEE_Guide.pdf
____________________________________________________
Historically, the concept of a 'hot' chassis goes back to the AC/DC AM radios of the 1950's(?)-- before my time. They actually had such things. These radios had two wire power plugs- the 'common' was directly connected to the chassis. Should anything open that return, the whole radio went "hot"-- this was in the days before the 'green wire' ground... and many were electrocuted.
While I am on a roll with Grounds, let me throw in a unique example.... the high power tube amplifier (transmitters too) with Pi-Net tuning outputs. Those familiar with these circuits know there is a high voltage capacitor between the amplifier tube(s) and the Pi-Net. It rare but sometimes that DC blocking capacitor fails- placing the full HV potential onto the antenna.... touch the antenna and..........Zap!
This happened to me once-- an apparent system failure- an HF antenna array failing to load.............. But nothing obvious show'd.
Hmmmmm--- First things first,
" Lets see what the SWR is on the antenna..."
so the amplifier was shut down and the antenna was being disconnected when ...."BAM !" ...........a Flash of Blue Light!
Even though the power was off, the residual voltage (++ thousand!) on the tube plates, had now shorted out directly to the antenna thru that failed capacitor-- it fortunately arc over to the chassis when the cable connector was being remove-- and not thru the Tech standing beside me.... leaving the two of us quite speechless.
How many of you out there have such amplifiers?... (we don't any longer!) Today I make sure that each new (tube) amp has an RF choke between the output coax and the chassis- providing a direct DC ground in case of such a short-out.... Pi-Net or no....
Just thought I mention that.
Tdenfuny, I'd highly advise you to look at that IEEE booklet.... it will answer your questions better than anything many of us can direct you towards.
.....................................CF
