Originally Posted by nd5y
A folded dipole is only 300 ohms and a regular dipole is only 72 ohms in free space away from all other conductive objects.
When you put them in a yagi array or very close to a metal mast like a stacked dipole array, the impedance changes.
As far as I know insulating or directly mounting the elements to the boom mainly affects how long you have to make the elements (the center of a dipole is a low voltage point and can be grounded). The calculator you used should tell you if it is for an insulated boom or not.
That's what I thought, but the calculator confused me by recommending a 4:1 balun as if the impudence was still 300 ohms. Thanks for the clarification. Is a 4:1 coax balun still good enough for a receive only application?
Thanks, that helps. I'm using a non-conductive boom now but I didn't know if I would increase gain by switching to a metallic one.
