Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 03-25-2009, 02:39 AM
Zard0z's Avatar
Send a message via Skype™ to Zard0z
Talking My First HomeBrew Antenna!
Ok I had fun making this Dipole antenna! Thanks to all here for the info. I plan on putting this on my
pole outside. It works great indoors almost as good as the Omni X at some freqs! Wow what fun this was.
All that is left is to get a bracket and get some cable. I will post a outside mounted pic when I can afford.
This cost more than one made in china but that was not the point.
So what do you all think... not too ugly
Z
RS pro-160
BC-246T
Antenna Omni X
Homebrew offset dipole
Old 03-25-2009, 08:51 AM
kb2vxa's Avatar
Nice looking job but why is one leg so much longer than the other?
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 03-25-2009, 08:54 AM
mdulrich's Avatar
http://www.radioreference.com/forums...al-dipole.html
The 9-12 Project http://www.the912project.com/
Streaming the Allen County, Ohio Scanner at http://www.radioreference.com/apps/audio/?feedId=188
Old 03-25-2009, 01:40 PM
specman's Avatar
Congrats on your antenna; I like your use of the conduit joint at your feedpoint there. I've been meaning to try one of these antennas to compare with my other stuff.
Jack
Old 03-25-2009, 01:51 PM
n4yek's Avatar
Nice and neat, good job!!
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 03-25-2009, 01:58 PM
Location: Davenport- home to me and the gators and the skeeters.
Default Good looking job Z.
Let us know how well it works. As you said, the price may be up and over store bought, but the thrill of building it yourself and getting great results is what it's about. Now you next project should be an 11 element yagi for the 800!
Freedom, a beautiful way of life. Roger
Old scanners like me:
Pro-44
Pro-94
Pro-2006
DX-440
Old 03-25-2009, 03:15 PM
AlmostHandy's Avatar
Send a message via Skype™ to AlmostHandy
Very nice job, dude! Homebrew antennas are really fun to make.
Definitely let us know how it works!
Old 03-26-2009, 05:54 AM
Zard0z's Avatar
hahahahaha. very funny! Way beyond my pay scale! (for now)
Thanks! I must admit that it turned out better than I thought. But it was a progression of sorts and
I did not share all of my pics!
Yeah it was the only way I could figure to get a indoor balun to be a outdoor one! Guess I could have made one or bought one that way.
I wanted to weather proof all of the componets and this is what I came up with!
I still have to seal the Balun area and use a rubber boot on the connector. I will use silicone to seal the gaps around the Balun and I have the boot already.
I won't do this step until I get my mounting bracket and drill the holes in the conduit. More pics as I finish it up!
BTW seems to work very well around the house! Kinda big for my desktop!
Thanks Guys
Z
RS pro-160
BC-246T
Antenna Omni X
Old 04-07-2009, 09:08 PM
Zard0z's Avatar
Default Got it!
Well I finnaly figured out how to mount my antenna to a standard 1 1/2 inch mast!
I will attached pics. I drilled the holes in the plastic connector box one size too small and the machine
screws I used threaded in nicley! Plus I put bolts on the inside for good measure.
Now all I have to do is to weather seal the exit hole with the balun in it and weather
proof the connectors. I have buryfelx cable to use once I get the other ten foot mast piece
placed on the side of my house. I will post final pics and preformance data when I finish up.
For now the long wire will be place on the top just to see how that works, then I will mount it
in reverse just to see if there is any difference.
Z
RS pro-160
BC-246T
Antenna Omni X
Old 04-07-2009, 09:57 PM
DDan's Avatar
Your metal mast is going to interfere with the antenna, IMO.
73 de Dan/w6kru
Yaesu FT-857 FT-90 VX-170 VX-3
BCD396XT BCD396T PRO-90 PRO-2050
Base RS 20-176 / Maxrad MFB8133 & MYA8256
Mobile Maxrad MUF8043
http://dansracephotos.com
Old 04-07-2009, 10:41 PM
specman's Avatar
Agreed. Although I admire the ingenuity of using commonly found parts for this, the mast is going to act in a negative parasitic manner in this case. The antenna needs to sit out a lot further from the mast; likely around a 1/4 wavelength or so of the lower portion of freqs this being used for.
Jack
Old 04-08-2009, 12:55 AM
Default biulding an antenna?
would love to try to build my own antenna. i only know that it needs a BNC conector to my scanner and that it can go outside but not too high like 8 to 10 feet total.. i need some some to help with a material and easy instructions ?? anyone care to help??
Old 04-08-2009, 03:12 AM
Yeah Zardoz, Get a piece of schedule 80 PVC conduit for the very top section of the mast. It only needs to be as long as the lower section of your dipole extends, so about 4 feet or so above the top of the metal mast. Your antenna doesn't look like it weighs a ton, and the wind shear will be minimal with it's low profile. I'm betting 1 1/2" sch80 PVC will work fine.
Old 04-08-2009, 03:15 AM
Hey a84b1! Building your own antenna is great fun!
It's actually pretty simple too. Zardoz here made an offset dipole. I've constructed a couple of vertical ground planes, and there are a couple of folks here who have put together their own homemade Yagis!
Check out the wiki section about scanner antennas. That's where I started. If you have any specific questions, just do a quick search in the antenna forum and see if anyone else has had the same question. If not, just ask us, we're here to help!
EDIT: Here's a link that takes you right to the homebrew scanner antenna section of the wiki. Check it out!!
Old 04-08-2009, 04:10 AM
Zard0z's Avatar
Default rodger that!
Ok great thanks guys! remember I am going to invert the top/bottom so the 18 inch wire will be pointing
down and the 48 up. The only thing is how to connect the PVC pipe/pole to the metal one. I will think
on this one..... Maybe try a 3 foot PVC piece first and the go as long as I can. Also I can move out
the antenna with a larger piece of metal but this might not be nessasary if the PVC works good!
Still I want to keep it as lightweight as I can. Thanks again for your good input everyone. I will get the
PVC and see what kind of monster I can come up with.
Z
RS pro-160
BC-246T
Antenna Omni X
Old 04-14-2009, 08:24 PM
Zard0z's Avatar
Default Polled!
Ok here is a couple of pics showing the mount design as of now! Thanks to everyones input.
So what do you all think? I am only concerned with the mating point of the metal pole and the
PVC pole. It will have to be tapped down to fit(this is good) but I don't know if my PVC cement
is going to be up for the job of weather weight and metal?
Will PVC cement work on mating to metal? It will fit real tight when I tap it down. In the pics
it is not tapped down all the way and holds the assembly better than I thought. If PVC cement
is not the answer what would be a better solution?
If anyone sees a problem please let me know. I still have to put connectors on my cable and
then she goes on the house!!!!!
PS I will be able to thread the coax thru the inside of the PVC and out the elbow joint! and then
down the metal pole......(end caps on pvc to keep water out) ...kewl huh!
Z
RS pro-160
BC-246T
Antenna Omni X
Old 04-14-2009, 09:19 PM
That looks great!
I wouldn't count on PVC glue holding to metal at all. It's designed to sort of melt the two plastic mating pieces together, effectively making a chemical weld. I would fit the two pieces together, and drill a hole completely through both walls of both pieces, and run a bolt with a couple of large washers. You won't need to torque it down very tight to get a good connection, and one of those urethane lined lock nuts can help if you don't want to use a threadlock compound.
Nice work!!
Old 04-15-2009, 06:33 PM
Send a message via AIM to digitalanalog Send a message via Yahoo to digitalanalog
It's a nice looking antenna, hope it works out well for you.
Great job.
Jim
Old 04-17-2009, 03:09 PM
Zard0z's Avatar
That looks great!
Nice work!!
Thanks, Great Idea on the bolt. I will drill and attach that way with washers!!
Looks like I will have room for a nice yagi underneath too!!
Z
RS pro-160
BC-246T
Antenna Omni X
Old 04-19-2009, 12:28 PM
KD8CPI's Avatar
Send a message via AIM to KD8CPI Send a message via MSN to KD8CPI
Thumbs up
I like that design. I made mine using the copper. It was comparible to the RS-170 except it was deaf on 800. I also like your idea on the coax down the tubes.
Pat yourself on the back, that is a great looking homebrew.
Brian
Fremont, Ohio
RS Pro-2055
BearCat BC895XLT
Yaesu ft-2800m
Yaesu ft8800r
Icom ic-229h
<<<< http://WX.Tatorz.com >>>>
Similar Threads
Handheld antenna recommendations pls wisesteward Antennas and Coax Forum 7 08-12-2009 12:28 AM
CAl Fire Air Ops "South Ops" connerspears California Radio Discussion Forum 23 06-30-2009 10:35 AM
800 mhz homebrew antenna? mass-man Antennas and Coax Forum 4 07-24-2006 10:19 PM
Homebrew Antenna jred184 Antennas and Coax Forum 0 06-08-2005 10:13 PM
RS 800Mhz antenna on RS Pro95 handheld radunn Antennas and Coax Forum 27 09-23-2004 10:44 AM
