Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 04-25-2009, 08:35 AM
Default My home built Dipole
Thought I'd share what my last project was, a home made Dipole.
It is made from 2m of 20mm aluminum tube, a 20mm conduit a "t" piece, 3 chair end caps, a couple of screws, a few pop rivets, a couple of terminals and coax to suit. All up cost me less than AU$40, and it outperforms any antenna I've had before.
This is it mounted to my hockey stick on the side of my house.
I know its a bit wonky, when I drilled the holes for the bracket I used my cordless and it wasnt on a straight surface.
For info on how to build see here
Old 04-25-2009, 10:07 PM
ridgescan's Avatar
Hmm.76 reads and not one reply...typical RR fashion-that's a cool one-what freqs are you monitoring with it? VHF high?
Uniden BC785D
Uniden BC350A
ICOM IC-R75
ICOM IC-R71A
dual Diamond D-130Js on the roof
...being "comfortable in my delusion"-THANKS!!
Pro 2066 in the truck with glassmount
73s-I am Frank
Old 04-25-2009, 10:31 PM
kb0nly's Avatar
I got busy otherwise i would have replied sooner! Looked at it but now that i got time to comment...
Nice job!
I see you put some wraps of the coax on the boom for a choke also, good job! What frequency is it for? Considering its length i'm guessing its not VHF.
www.kb0nly.net
www.jeepkj.com
Old 04-26-2009, 03:32 AM
n4yek's Avatar
He cut it for 421 MHz according to the link below his picture in post #48 of that forum.
Danny Harp Jr.
HAM Radio Operator: N4YEK
Old 04-26-2009, 07:04 AM
Send a message via AIM to digitalanalog Send a message via Yahoo to digitalanalog
Nicely done, thanks for sharing
Old 04-26-2009, 03:49 PM
Zard0z's Avatar
Send a message via Skype™ to Zard0z
Default Good Job!
Nice work! I always like to see the home made stuff! I just made a offest Dipole myself.
I was amazed like you how well the do work!! Plus I had a blast so far building it. Mine
cost more cause i needed supplies but my next one will cost less
Let us know if you can get a wide range of freq's than what it was built for! I would be
interested in any performace data that you come up with.
Z
RS pro-160
BC-246T
Antenna Omni X
Homebrew offset dipole
Old 04-29-2009, 10:54 PM
I built it primarily for 421-422 mhz as that is what the Ambo's and Metro Fire use around here, but it performs just as well at 163 & past 500mhz too. I use it on my 396 and it can pick up 800mhz systems from about 45km's away without fail
Old 04-30-2009, 10:45 PM
kb2vxa's Avatar
I'm not surprised, it's a half wave on 400 and a full wave on 800. It's a BS impedance on 500 but what the heck, it works. Now MY questions are what is a "hockey stick" antenna and is the dipole mounted to an active antenna element or is that the support for what is above it? It may sound silly but what prompted me to ask is in my neighborhood there is a scanner antenna mounted ON a CB antenna without a mast, the mounting sleeve is held by a single wall bracket. Yeah, he's using one antenna to support another... CBsexy (whacker) style.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 04-30-2009, 10:58 PM
alfapapamike's Avatar
Nice job ausscan, it looks pro!
I proof-of-concept built a dipole out of two old shelving support tubes, zip tied to a paintbrush handle. Just goes to show that with sound mathematics and measuring you can build a decent antenna with just about anything. Pulls in stuff way better than anything I've used too.
Old 05-02-2009, 12:17 AM
The "hockey stick" is the fascia that mounts on the eaves, and what the antennas are actually mounted on. The 4.5db whip was going to be for a local UHF CB but the base appears to be grounding out, and I'm not planning on fixing it until I move.
Old 05-03-2009, 05:04 AM
kb2vxa's Avatar
I see, sort of. (;->) The mast and antennas silhouetted against the clouds really stand out but are too dark to see much detail which is why I asked so thanks for clarifying. Now I REALLY should have thought of this before, DUH. Here we are again, after cropping and a little gamma correction the detail comes out even if the picture looks a little grainy.
73 de Warren
Old 05-17-2009, 09:22 AM
Just an update, I built another one just to see how much it would really cost me.
1m Aluminum pole - $8
"T" peice - $3
U Bolt/clamp - $6
Had lying around the rest, so for the best part of $20 I have myself a brand spanking new antenna. Here are the pics:
And this is how it ended up in the sky:
Similar Threads
LA Area ambulance companies flashover Greater Los Angeles & Inland Areas Discussion 30 12-12-2008 08:58 PM
multiban dipole feed? kd6zxe Antennas and Coax Forum 5 11-29-2007 05:23 PM
Oriskany FD in Oneida Co changing home alert frequencies c0untyb0y New York Radio Discussion Forum 13 08-02-2006 08:51 PM
Need Home Repeaters for Venetian Hotel--Can Pro-97 Users Help? dtscho Nevada Radio Discussion Forum 6 12-14-2005 06:08 PM
question about LTR Passport "trunkoff" frequencies mr_hankey LTR Trunking 4 05-23-2004 10:18 AM
