Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 06-01-2009, 06:37 AM
Send a message via AIM to jparks29 Send a message via MSN to jparks29 Send a message via Yahoo to jparks29
Default Thoughts on hidden, bumper mounted, wire dipole?
Looking at going low profile, only way I can think of doing that is with a wire dipole mounted behind the bumper...
Two problems I'm thinking of...
Vertical Vs. Horizontal polarization, easy 3-6db loss.... Reflection from metal bumper, which would be within about 2 inches from the antenna itself....
Looking @ vhf/uhf @ 110 watts...
Suggestions?
Old 06-01-2009, 07:33 AM
I guess the big question is just why would you want to do this? There has been a requirement
over the years to come up with some sort of covert or unseen antennas. These generally do
not perform very well and have poor range.
If your looking to just do this for no real reason, then have at it. If your looking to maintain
good communications and just don't like antennas sprouting from the roof of the vehicle,
that is a whole different prospective.
You will probably do better in obtaining suggestions, if you provided just a little more of a
hint on how you intend to use the antenna and what kind or range your expecting to obtain.
Jim
Suggestions?
Jim
Old 06-01-2009, 08:12 AM
jhooten's Avatar
Sti-Co: Custom Antenna Supplier and Manufacturer: Covert Antennas
Jerry
I read it on the internet, so it must be true.
Old 06-01-2009, 08:39 AM
Fast1eddie's Avatar
Can you mount a unity gain antenna inside on the rear deck??? I am going to put one in my '07 Milan and have seen them in police cars. They work well, but can have directional and blocking tenencies due to shielding.
Edward Hutton
Cross polarization losses are typically around 20 db.
Between cross polarization losses, and the effects of proximity to the bumper, it's a fair bet taht it won't work well, and probably lots of directions where it won't radiate at all.
Suggestions?
That's a lot of power to waste...
Why don't you tell us what kind of car it is, so people can suggest better locations.
12 volt radios are for wimps. Real radios can kill you.
Old 06-01-2009, 08:53 AM
Send a message via AIM to fineshot1
Suggestions?
I installed one of these antennas once with very disapointing results for the owner
and he did not have a 110W radio. I think they are a gimmick/garbage and would not
recomend it especially with a 110W radio. Most stealth antennas are not rated for
110W and also for the reasons you stated above I would steer clear of them.
fineshot1
NJ USA
Old 06-01-2009, 09:50 AM
Check this site out that's a friend of mine:
Disguised undercover covert license plate antenna,fender,cowel,bumper antennas
The license plate antenna is a real compromise but if its for undercover work in a large public radio system that is designed to work well with hand helds, (voter receivers, etc) it should work ok. A friend installed one for general purpose amateur/GMRS use and it was very disappointing.
I've made and used simple 1/4 wave verticals from thin wire taped to a window with two ground radials along the lower window and it works surprisingly well but 110 watts inside a vehicle would be a health hazard.
prcguy
prcguy
Old 06-01-2009, 10:52 AM
I second the motion for the rear deck, I installed many an antenna on the rear shelf for the DEA in the 70's and 80's. To hide them a little better we would take a Kleenex box and put it over the antenna. Problems foreseen today are rear window defoggers, creates an electric field as if it were sheet metal. You could also install the whip by the A pillars in the front of the car, I also had installed what would be described as a curb feeler antenna. Worked sufficently for the Chief of the department who didn't want an antenna seen on his car. Stay away from cross polarization, keep the antenna verticle at the very least, where ever you mount it.
Old 06-01-2009, 12:51 PM
gewecke's Avatar
Years ago I installed a quarter wave nmo on the rear package shelf of my 88 dodge diplomat. Uhf was 4" from left pillar nad vhf was 4" from the right. These worked quite well as this car did not have the rear defogger! The FBI favored this idea back then on many of their covert vehicles.
N9ZAS.
Old 06-01-2009, 04:11 PM
whip on rear deck is not good. the car creates a farraday cage, and pumps 110W into the back of my skull and goes through the defroster grid... BAD idea.
It'll be in a crown vic, stealth is a must. Can NOT use disguise fender mount antennas since they don't have any (except oddball '05 MY).
Old 06-01-2009, 06:50 PM
jhooten's Avatar
In glass antenna?
Sti-Co: Custom Antenna Supplier and Manufacturer: Embedded Antenna System
Jerry
Old 06-01-2009, 07:08 PM
Originally Posted by jhooten View Post
They've been known to crack rear glass...
Similar Threads
Long Wire Transformer / DIY Antenna andrewccm Antennas and Coax Forum 9 06-14-2008 04:58 AM
300 to 75 ohm TV balun for dipole / wire loop antenna? walterb Antennas and Coax Forum 9 06-12-2008 09:16 PM
Hoops and Loops - Just plain old wire Pro-95 Antennas and Coax Forum 6 10-20-2005 06:31 PM
Is the Blocked Cellular Freq range on Scanners still needed? bear105 General Scanning Forum 52 12-05-2004 09:19 PM
