Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 06-09-2009, 03:39 AM
Default Simple indoor / attic coax rf-choke
Here's a shot of one of my favorite new accessories - a common mode cable choke.
The coax is just hand formed to about 3-1/2 inches and wound as a solenoid, that is each loop is next to each other. Around this are Radio Shack #273-104 snap-on ferrite chokes. I really like these ferrites as they come with some specs and documentation. Apparently the material is effective up to about 500 mhz. Make sure you snap these back together tightly.
I could wind about 2 turns of RG-6, or 3 turns of RG-59. I'm only using a short run to the attic, predominantly at 118-135 mHz so I don't feel the need to run heliax, but do check out other threads on cable attenuation.
In the pic, I use something like a "binocular" version. Other options are just stacking them on one side, stacking more on each side, or even using none at all and just winding about 5 to 6 turns together. I like to get fancy here as the ferrites provide about 12db of gain. Just kidding.
I actually use 4 ferrites - two on each side, but use just two here for illustration.
I use it very close to the feedpoint of dipoles, just below the tips of the radials of ground planes, or actually choke the feedline at 1/4 wave away from the feedpoint with other antennas to purposely use some of the common-mode current -- to trick an antenna into using a different pattern. (My deepest thanks to W8JI and W7EL)
Offset-fed antennas and those that use tv-type "baluns" need these, as the balun in an offset fed antenna is totally swamped by the severe non-symetrical setup, along with the fact that the voltage-baluns that are inside most tv-type baluns make the situation even worse. So while the tv-type balun might help with impedance transformation, you need to make up for the missing balun-action with an rf-choke.
In some cases, these chokes may stop severe common-mode current coming from your shack, and traveling up to the antenna. You may find some locked-out channels usable again. Maybe.
For a couple of turns of coax and some cheap ferrites, these go on every antenna I use these days....
Old 06-18-2009, 04:24 AM
K6STI shows a great way to wind one for the FM broadcast band and you can see it in action on a spectrum analyzer.
Simple 75Ω Coax Balun
Old 06-20-2009, 04:36 AM
Now that I think about it, this might be overkill for scanning multiple bands.
In this case, I just stacked about 4 of these together, but instead of tightly tie-wrapping the coax turns, I left them separated all fanned out around the chokes.
Similar Threads
The simple Coax Loop works lanbergld Antennas and Coax Forum 8 05-29-2009 03:42 AM
What happened to my coax? (Tiny holes in outside) safetyobc Antennas and Coax Forum 29 07-07-2006 01:38 AM
Scantenna Problems - Remedy safetyobc Antennas and Coax Forum 3 04-13-2006 10:41 PM
A SIMPLE coax loop antenna for apts, HF oceans777 HF/MW/LW General Discussion 3 02-13-2006 01:53 PM
Simple and easy Air monitoring antenna kf4lne Aircraft Monitoring Forum 0 08-18-2005 03:56 PM
