Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 06-16-2009, 08:30 AM
Default Using a MFJ antenna analyzer
So I put up a 2 meter antenna on the house. Used Belden 9913 coax. I hook up the MFJ 259B analyzer, says the match is a beautiful thing. But also says I have 5.8 dB loss in the coax.
I'm sure folks here have used the MFJ, is this thing saying that I'm losing half my signal in the coax? Is the "loss in the coax" reading an accurate reading? If I remember right, 6dB is double the signal, so a 6dB loss is half the signal. (I think).
It's only about a 30' run, if that. I'm full copy on machines 50 miles away.
Old 06-16-2009, 08:36 AM
N_Jay's Avatar
In power 6, dB is 3/4 of the signal lost. (Not that it matters).
6dB is typically only one "S Unit".
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 06-16-2009, 08:57 AM
I have one of those and they don't seem to be real accurate.
Are you measuring coax loss with the antenna connected? It won't work.
Tom
Old 06-16-2009, 01:12 PM
Default SO I'm doing wrong
Yes, that's exactly what I am doing. Oh well, I'll never know then. I'm not going to go back up and disconnect the feedline from the antenna just to find out what the coax loss is. Thanks for the help.
Old 06-16-2009, 01:32 PM
I beleive the line loss must be done with the antenna disconnected form the coax. I suspect its attached in your measurements. 30ft of 9913 has about 1db of loss, even at 1000ft is only has 4db of loss. Either you have a bad cable or are not using the meter correctly.
Old 06-19-2009, 07:07 PM
In power, a 3 dB decrease means a loss of about 50% of your original signal. A 5.8 dB loss means your signal is almost 1/4 of its original strength. That's large but practically 3 dB represents about one S-unit so you're down almost two S-units. Not huge but not insignificant either.
9913 is known to be good coax provided it is properly waterproofed. If you have an old and "wet" piece it's going to be all screwed up.
Similar Threads
Antenna Recommendations very weird problems+ my bad luck Jono40141 Antennas and Coax Forum 6 12-27-2007 07:02 PM
Indoor Attic Antenna for High Def Dish Network tuner cousinvinny Antennas and Coax Forum 5 07-08-2007 02:16 AM
Antenna Analyzer Bob_314 Antennas and Coax Forum 2 11-06-2006 10:48 AM
Antenna Analyzer for Milair Band? BenJJ Antennas and Coax Forum 2 10-27-2006 09:42 PM
MFJ 1729 Dual 2M/440 antenna blackbelter Antennas and Coax Forum 6 09-27-2006 02:17 PM
