| Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities. |
10-09-2009, 04:49 PM
Yagi
Looking to by a yagi antenna but not sure which one to buy and what is the difference between the4 and 8 element and what db do I get Thanks
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
10-09-2009, 05:17 PM
Best yagi antenna
Can you give us a little more to go on? Like a band or bands to be covered, type of scanner/radio, & coax used or looking to use, price ceiling, etc. Also check thr RR antennas WIKI for additional information.
FLRAILMAN
10-09-2009, 05:33 PM
The greater number of elements, the more gain the antenna will have. How much gain you need depends on your particular circumstances.
What are you hoping to gain? (no pun intended)
10-09-2009, 06:37 PM
Yagis are both directional and designed for a specific frequency.. so you would only want/need one if you have a signal that is from a specific area and a specific frequency. Of course they are not so specific that they only receive one frequency and will receive a range of frequencies both below and above the target frequency but the range is not so wide as to cover a large spectrum.
KJ4ODY
FT-7900R | BR330T | Pro-160 (2) | Pro-94 | Pro 34
10-09-2009, 09:57 PM
Yagi
Looking to pick up a tower apx 20 miles north of me can get two bars with just the rs 800mhz antenna hoping a yagi would help improve that
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
10-09-2009, 10:28 PM
yagi
One more question where is a good place to pick up some lmr 400 cable
pro 83
(2) Pro 96
pro 97
psr500
pro 2022
pro 164
10-10-2009, 02:29 AM
If you can't find it locally, there's tons of that on Ebay as well. Have you considered using RG6 TV coax? It's 75 ohm, rather than 50 ohm, but for receive only, it will work just fine! It's smaller, less expensive, and low loss.
10-10-2009, 10:00 AM
Can you buy RG6 with BNC connectors on it? (if so where?)
If not, would there be a big loss if you used an adapter to change it from the regular cable connector to BNC? What is that F type female to BNC male righ?
10-10-2009, 11:30 AM
You would need a Type N Male-to-F Female adapter for the antenna end, and a F Female-to-BNC Male adapter for the scanner end. The RG6 cable would have a F Male on both ends.
These adapters will not cause a big loss, and will work fine. Several members here on RR have done this with great success.
10-10-2009, 07:27 PM
Sounds like a good idea, I know I have some RG6 and RG58 (or 59?) lengths laying around from various TVs etc. Go get me some of those connectors then.
10-10-2009, 07:45 PM
Stick with the RG6, definitely not the RG58, too much loss at 800MHz.
10-10-2009, 08:59 PM
What about RG59? I can't remember which we have lying around if it is 58 or 59
10-10-2009, 10:03 PM
How many feet do you need to run?
10-11-2009, 09:19 PM
Not sure yet, it will be split to go to 4 scanners. 10-25 feet probably.
10-11-2009, 09:23 PM
RG59 should be fine. RG6 is shielded a little better.
10-11-2009, 11:26 PM
Originally Posted by n5ims
$80.00 vs. $5.00, I don't understand your logic? I could see it if he was going to be making up cables on a regular basis. But that's a big investment to make one connection.
