Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 10-11-2009, 08:58 PM
Default RadioShack Magnet Mount - Frequencies?
What are the RS magnetic mount (the one with the two loading coils in the mast) frequencies?
Old 10-11-2009, 09:08 PM
MPSCS's Avatar
They claim it to be a wide-band antenna covering 25MHz - 1300MHz. While it's true, it's capable of receiving frequencies in that range, so is a wire coat hanger. How well it does it is another story. But overall it's not a bad general coverage scanner antenna for the money.
They don't stay on the car too well at speeds over 60 MPH.
Old 10-11-2009, 09:11 PM
I have one, but bought it so long ago that I don't have the owner's manual. I was wondering if they performed better on certain bands better than others?
Old 10-11-2009, 09:14 PM
MPSCS's Avatar
I'd say 150MHz band, 450MHz band, and just OK for the 800MHz band.
Old 10-11-2009, 09:20 PM
gewecke's Avatar
Post
Someone had experimented awhile back and posted his measurements on RR for this antenna,but I don't recall what bands he cut the whips for or which one(s)
N9ZAS
Old 10-13-2009, 12:12 PM
izzyj4's Avatar
I've owned one for many years and never have a problem from 33 on up through the 800. Good reception. I bought it with a MOT plug and later changed out to a BNC when I bought my old Pro 2046. Always worked good for me
| BCD396T | BCD996T | BC780XLT | PRO 2006 | PRO 2046 | BC560XLT | BC780XLT w/ Scanner Master remote head kit | TRS-452 | TRS-453 |
Old 10-22-2009, 02:54 AM
Send a message via Yahoo to conve36
This antenna is GREAT for monitoring ALL scanner freqs... to a limit of course. When I had this antenna, I used it to monitor my Counties Sheriff's Department. They were on an 800Mhz EDACS trunking system with multiple sites. So basically I could hear them with ANY antenna I attached to my scanner.
What I really wanted was to be able to monitor California Highway Patrol while traveling the local freeways. They use an older VHF-low (39.68Mhz) radio system. It is difficult to hear with rubber duck antennas, making them useless.
I found that Radio Shacks Mag-Mount Scanner antenna worked GREAT for monitoring the VHF-low freqs, as well as anything thing in the UHF band. (And of course 800Mhz).
Also, I found that this antenna actually works well as a dual-band transmit antenna for VHF/UHF on low power (5w).
And if anyone tells you they fall off their car, they need to wash the damn thing before putting it on. This thing didnt move an inch while hitting speeds over 90MPH from San Diego to Los Angeles on the trunk of my convertible BMW.
One more thing, it's always fun to experiment with this antenna by removing elements or adding elements or even cutting a rod for a specific length/frequency.
Hope that helps! Have fun!
Old 10-26-2009, 11:51 PM
NCVFD1's Avatar
Send a message via MSN to NCVFD1 Send a message via Yahoo to NCVFD1
Go To WiKi for that antenna its there how to redo it =IT WORKS for me
Old 10-26-2009, 11:54 PM
NCVFD1's Avatar
under homebrew -RS modifying magmount
Old 10-27-2009, 09:38 AM
Interesting...I just happen to have a 102" whip that the mounting stud broke off that I can cut up...
Old 10-29-2009, 01:04 PM
I did the same thing! But I use it as a base antenna, although it's a great mag-mount, no way would hold up with any rod over 36" (but who knows!).
Old 10-29-2009, 05:17 PM
NCVFD1's Avatar
it works on my car at 65mph
Old 10-29-2009, 08:28 PM
Smile
i'm not bad mouthing the r.s. antenna. however,for like $15.00 one of those little valor magnetic mount antennas with the mini coax, will do just as well. don't expect much from vhf-lo band though. the other advantage is that it come's right off/goes right on the car in a snap.
