Againts my better judgement (I HATE Radio Shack a/k/a Ratshack products) but that's just me, Without knowing your explicit mounting situation I would recommend the following items:
Chimney ratchet mount.
Model: 15-0839
Catalog #15-839
$24.99
And:
5' antenna mast.
Model: 1016-5P
Catalog #15-297
$14.99
Or
10' Antenna mast.
Model: 1016-10
Catalog #15-298
$24.99
In high wind or icy areas I have seen chimney mounts actually separate the chimney from houses if the chimney is located at the end of a house due to wind load stress the antenna(S) & mounts create. And if the chimney is mounted at the end or middle of the house such mounts wind movements & element vibration can cause a roof leak. If I were you I would seriously consider an alternate mounting method, eave mount, tripod mount or some other alternate method.
RadioShack - mobile phones, MP3 players, laptops, and more
Click on: "home enterntainment" then click on "antennas" then click on "acessories"
I hope someone else will reply with a better solution for you & proper grounding methods, good luck.
FLRAILMAN
