Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 10-20-2009, 01:12 AM
Default Mobile scanner antenna for home use
Just curious how well this would work,
I have an older bearcat scanner in my house. I am using it with the factory telescoping antenna. reception is fair, but lacking from time to time.
I also have a magnetic mount full range mobile antenna here. also have another similar antenna with an NMO mount. I also have spare NMO mounts with wiring. How well would it work if I mounted one of these antennas up near the roof of my house and then bout a plug-adapter to plug this antenna into my bearcat scanner??
any advantages to one antenna over the other?
I figure getting the antennas outside into "clean air" and up higher has to help with reception.
if it makes a difference I monitor 39mhz - 155-157mhz - 460mhz
Thanks for any ideas/suggestions
Old 10-20-2009, 10:32 AM
It should help a bit, the problem is that mobile antennas use the car as a counterpoise so it helps with the level of signal you will receive. You would be better off with an actual base antenna that isn't designed to have a counterpoise (ground plane) in the same way most mobile antennas are.
Wire it all up and just stick it on a fence or a table outside before you go through the trouble of roof mounting it. Should give you a pretty quick idea.
http://www.kc2rgw.com/
Various info on SDR, ham radio, monitoring, and rantings of a lunatic.
Old 10-20-2009, 09:17 PM
KT4HX's Avatar
Send a message via Yahoo to KT4HX
I use a Larsen NMO 2/70B magmounted to an old cookie sheet (a metal filing cabinet is a good counterpoise as well) in an upstairs room. I really like the reception (VHF/UHF/800) I get for my local city/county as well as my surrounding counties and State PD. But obviously, it would do better outside. But in reality a regular base station antenna mounted up in the air would be better.
Alan
Scanners: PSR-600 | PRO-106 | BCT-15
Old 10-20-2009, 09:22 PM
Thanks for the info guys. I was wondering about the whole ground plane thing.... Oh well a base antenna doesn't appear to be very expensive anyhow.
Thanks!!
Old 10-20-2009, 09:29 PM
NYRHKY94's Avatar
One of my live feeds runs off of an Antennex ABSCANC Tri-Band magnet mount antenna inside the house with good results. I have it placed on the center of a large cookie sheet. Does a surpisingly good job both in terms of signal distance & sound quality.
Thanks - Mike
PSR-600, Pro-106, Pro-2096, Pro-96, Pro-2053, Pro-2052, BCD996T, BC796D, BC898T, BC370CRS, BC210XLT
Listen to my feeds at:
Radio Reference NH
Radio Reference NJ
