Originally Posted by OC05450R
Does anyone have or can take pictures of there different antennas and how they are mounted in their attics? I have a radio shack scanner that I need better signal without going outdoors. I would like to do 2 antennas one good for low band and one for vhf/uhf and I would like them to go to one scanner. If this is possible please let me know. I don't want to spend a ton of money just something simple. Thanks in advance -JOEYD
You can really use what ever antenna that will fit in your attic, get some good coax for the run from antenna too scanner and all you need is a splitter for hooking everything together, if you have room for a antenna stand there are many outdoor ones you may be able to use or just make one.
Steve
