Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 10-22-2009, 02:44 PM
Send a message via Yahoo to conve36
Default Question regarding J-POLE feedpoint
As in the picture below, my question is; (measurments not exact, just example)
If I am to attach the PL-259 chassis mount at say 1.5inches from the grounding point, where do i stop measuring? The middle of the chassis mount or the closest end of the chassis mount to the grounding point?
This is a hard question to "word" so I hope someone understands what I mean...
Old 10-22-2009, 06:40 PM
I don't think it is all that critical. Have you made any measurements to ensure where you have the mount positioned gives you the best SWR?
On the j-poles I've made I strip the braid from the centre conductor of the coax and attach them to each j-pole leg using stainless steel hose (worm) clamps.
Old 10-22-2009, 07:07 PM
Default J-pole
I agree with mrweather. Skip the SO-239 connector, and clamp the center and shield directly to the copper cactus. This way, you can move the feedpoint up and down a bit to get the best match.
Old 11-10-2009, 02:03 AM
The measurements are usually from the center of the tee.
Um, I'll be a smart-aleck and hope you aren't trying to use that piece of coax in the pic.
At any rate, be sure you do something about common-mode ground currents with either ferrite RF-chokes good up to VHF a few inches down the feedpoint cable, or at least use a few loops of coax (I don't know the magic for coaxial-loop chokes, ie 4-inches, 4 turns, --- 5 inches, 5 turns etc -- you may want to look that up for the band of interest). Note that I've never seen ferrite chokes good beyond 200-300 mhz so ferrite chokes for a UHF version may be hard to find.
Then tune it.
This link may prove useful if you go at least half-way down the long page about the effects of common-mode currents changing patterns as compared to antennas modeled without any feedline attached:
End-fed vertical j-pole and horizontal zepp I-max 2000 vertical
Many antennas are actually looking pretty high upwards, and have their feedline doing the low-angle work poorly - which should really be left to the antenna proper to do.
Good luck with your antenna - they are a blast to make - and I've got the cuts and burned thumbs to prove it.
Old 11-11-2009, 02:24 AM
I never really understood the popularity of the J-pole.
12 volt radios are for wimps. Real radios can kill you.
Old 11-11-2009, 07:24 PM
I can think of a few:
- easy to build
- DC grounded
- doesn't require a groundplane
Unread Today, 02:34 PM
Best way to determine proper point of attachment is to use an OLD swr bridge (CB) and solder after best swr is attained. not knowing what freq used it's hard to say what to use for xmitter. if you have a gmrs radio you can use it to get close enough to 400mhz to be efficiant enough. could use a grid dip and amp to get enough power to run meter.
