Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 10-22-2009, 04:06 PM
Question help with ground loop on antena
i have a 48 inch half wave 27mhz CB antenna mounted outdoors with the lead in made with rg58 coax with an approx length of 54 feet it has terrible reception on all bands except for the Motorola trunking control frequencies 475.3750-947.3500mhz im using it with a pro 164 tri trunking scanner and when i hook my home theater system to it for an external speaker i geta ground loop that puts approx 21.3 volts ac on the shield of the coax and this is on a non grounded antena system and the reciver i use for an external speaker has a two prong polorized plug hard wired to it so there is no source of grounding from that to account for a ground loop help me figure this one out
Old 10-22-2009, 04:14 PM
N_Jay's Avatar
Find a good ground, the measure the audio ground of the TV system, the shield of the antenna and the case of the scanner each independently.
Report back.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Tags
bad reception, grounding
