Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 10-26-2009, 08:42 PM
Default Three Postition Antenna Switch ?
Hello To All
I looking for a 3 postition antenna switch for a scanner. I would like it to go up to 870mhz. The only one
I go find was the one below. If someone knows of another one,please let me know. Not sure if this would be
the correct one. Thanks
CX3, COAXIAL CABLE SWITCH BOX - 3 POSITION - USE WITH TWO WAY RADIOS - Scanner World - The Largest Dealer of Scanning Radios in the World
Old 10-27-2009, 01:18 AM
FLRAILMAN's Avatar
Default 3 position antenna switch
Welcome to Radioreference where there is no such thing as a stupid question. I noticed that your basic requirements are that you need at least three RF outputs & they must cover up to 870.0 MHz. The switch in your link does not specify it's usable frequency range, have you checked with Scanner World about that? Also any component in any communications system be it professional grade transceivers or consumer grade scanners needing to cover up to & past 800.0 MHz are configured differently then most economical communications products available. Most consumer grade coax switches only cover up to 800.0 MHz & utilize SO239 female sockets which are not really suitable for the best possible reception at those frequencies. Anything above the UHF range should be oufitted with N connectors exclusively however if cost & the possibility of having to compromise your system by using additional adapters between your antenna & scanner is a factor then get what you can afford. It's after 1:00AM here & I am whacked out however I did find two companies that have coax switches that may work for you, they are a little pricey but at least it's a start in pointing you in the right direction if you feel that these won't work for you.
www.alphadelta.com
Model: Delta-4B/N 4 position surge protected coax switch
RF coverage up to 1.3 GHz
N connectors (50 Ohm)
$99.95
Cables, Coaxial Cable, Cable Connectors, Adapters, Attenuators, Microwave Parts - Pasternack Enterprises
Model: PE7140 4 position surge protected coax switch
$167.15
As I mentioned, they are a little pricey because they are targeted for the professional communications industry. Maybe another RR member will read this thread & come up with something a little more viable and/or affordable for you. Good luck.
FLRAILMAN
Old 10-27-2009, 04:12 AM
scottaschultz's Avatar
Diamond also makes an 800MHz switch, but it is also pricey. The model CX-310 sells for $85 HRO Ham Radio Outlet and $90 at AES
You might want to get familiar with these places anyway since they are two of the "biggies" for amateur radio gear and accessories like this.
Scott - NĜIU
