Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 11-01-2009, 12:18 AM
Pete27a's Avatar
Default The Best Pick Up Truck Scanner Antenna
Ok I am looking for peoples advice on what is the best scanner antenna for a Ford Ranger Pick Up Truck. Right now I am just using the antenna off the radio of the truck and it is not working to good. I would like evryones advice on what they think would work best installed on a pick up truck. I need the antenna to receive on all bands, do to that were I live I have a lot of everthing to listen to and it is all mixed from low band right to 900 trunk. So let me know what you guys think. Thanks for your time..Pete
Old 11-01-2009, 12:26 AM
gewecke's Avatar
Smile
Well if you have a tool box behind the cab that's a good spot for an all-band scanner antenna which can be had at radio shack for about $30+tax or you could put it on the roof which would be my first choice.
N9ZAS
Old 11-03-2009, 10:16 AM
JStemann's Avatar
I have a larsen nmo 150/450/800 antenna that does real well on most bands and runs about $30. It's about 21" tall or so, you can use it with a mag mount or drill a hole. The austin spectra is a great antenna especially for the lower bands, it also does ok if you have anything down in the 42-44 mhz area. It uses an nmo style mount, is about 33" tall and will run somewhere close to $100.
I have both and they both do very well, the taller spectra does better on the lower bands and they're about = on the 800 band. The shorter larsen doesn't do very well down in the 40's.
jeff s.
kc9ftp
BC-396xt, RS Pro-96, BC-785D, BC-996t, IC-92AD, Ft-7800, Ft-897D, Kenwood Tm-D710
