Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 11-01-2009, 12:21 AM
wv_mountaineer's Avatar
Send a message via Yahoo to wv_mountaineer
Question Larsen 3/4" NMO Roof Mount
I want to buy this roof mount however I need to know if I can use this on a piece of flat stock steel that I am going to have to use. First off I bet this sounds dumb to you but let me explain...
I am going to put this on a mirror of a tractor trailer. So this is going to be a mirror mount unit. I have a piece of flat stock steel already made with the 3/4" hole needed to use said NMO antenna roof mount. I know a car roof is not very thick so I need to know before I buy if I am going to have enough threads to attach this to my flat stock piece of steel. I am guessing it is about 1/8" to less than a 1/4" thick. Anyone have a clue if I am going to have enough threads to be able to make this work at all?
Old 11-01-2009, 08:30 AM
rfradioconsult's Avatar
Look around you can buy NMO style mounts for mounting on larger thickness materials, just start seaching, don't settle for a standard mount find the one you know will work for your needs.
Old 11-01-2009, 08:57 AM
Wirelessly posted (BlackBerry8310/4.5.0.110 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/-1 UP.Link/6.3.1.20.06.3.1.20.0)
Antenna Specialists used to make a nmo mount for multi thickness's. I may even have 1 on my shelf. You can also buy pre-made nmo mounts on the bracket for semi mirrors (maxrad and childs) used to and may still make them.
Old 11-01-2009, 11:17 AM
This mount uses regular NMO mount:
Mirror Mount Brackets - 3/4" 90 deg Mirror brkt
If you go thicker than 18 or 16 gauge sheet, use a thick mount:
Thick Surface Mounts - 3/8" or 3/4" - 3/8" Brass Mt,ThickPlate
