Can't hurt, I've seen plenty of older commercial ground planes with radial skirts. They lower the vertical radiation angle somewhat giving a slight additional gain and "decouple" the antenna by reducing common mode currents on the outer conductor of the coax.
BTW, don't think that RS antenna is a dual bander. Although a 1/4 wave on 2M is a 3/4 wave on 70cM and also presents a 50 ohm load it has a higher vertical takeoff angle so while it'll work a 1/4 wave ground plane works somewhat better. Now here's a bee in your bonnet, you could fabricate a mount with radials and use a quality dual band mobile antenna. I've done it several times with excellent results using high gain UHF commercial antennas, yours should be similar. As a matter of fact I'm using a 6dB gain 800MHz mobile antenna that way and it's working like a champ.
OH! I just noticed you plan on using the ring, don't. I said above that it's a gamma matching section to lower the feed point impedance to 50 ohms so just unscrew the coax from the antenna itself and screw it into the ground plane.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
