Originally Posted by wvufan
Thanks n8uxf I have been trying to figure how to listen to the WVSP ever since I got my first scanner. Any suggestions on a cheap outdoor antenna?
High up with
VERY low loss cable (which isn't too difficult on 70 MHz). You aren't going to put up a high-gain antenna on that frequency - a real-world quarter wave is 39 inches, so a gain antenna is going to be almost 10 feet tall for just a little gain . (Even a ground plane will be a bit higher than 39 inches, and it's pretty cheap to make, but you'll have to make it yourself or buy a commercial one - there aren't any cheap antennas for that frequency range. It wouldn't be too difficult to cut down a CB ground plane.)
Although I can only find one use of 72.36 MHz listed, and that's in Welch & Caretta so, if you're not in those areas, you're not going to hear anything unless you're ready to spend
lots of money on an antenna.
