Thanks to all for the great comments and ideas.
LtDoc,
Instead of using a balun to change impedances, and depending on how those 'ears' are made to start with, why not just change the feed line to 50 ohm coax?
That's what I plan on using the rg-58 for, the feedline, but don't I still need to match the impedance of the "ears" to the line? Also my radio is only a HT, so putting the "ears" on top would be extremely difficult :lol:...the article suggest using it vertically. Thanks for the safety warning, but I don't plan to be anywhere near that thing.
prcguy
If you make the elements 19 to 20" long each the feed point impedance will be around 50 to 75ohms and you would feed it directly with coax. a TV transformer will probably handle a few watts but they are a bit lossy and I would avoid them whenever possible.
That is excellent news as I would rather not use a TV Xformer. Can you tell me how you figured out the impedance to be 50 - 75 ohms for 20"?
W2NJS, yep, the article explains to use it vertically (you didn't read it, huh) :wink:
pjtnascar
That is a cool little antenna! If you're into the copper pipe thing, do a search for the 2 meter hentenna.
I took a look at that and I probably will build one of those next...this time I want something super cheap, super easy that will work well.
AK4GA
My suggestion would be the twinlead j-pole. Plus the J-pole is much easier to hang vertical.
I have the materials for that except for a ferrite bead that my buddy says he has in his junk box. I will probably build this first as I am having a hell of a time finding the "ears"...I have looked in every thrift store in town, nobody has one....people just laugh at me when I ask for one.
Thanks to all for your helpful replies. If anyone has any more ideas, keep 'em comin'.
