Originally Posted by cousinvinny
I believe I need an HD antenna (in attic) so I can pull-in local channels in HD.
To an antenna there's no difference between HDTV, normal TV and two-way radio on the same frequency (other than polarization). You may need an antenna, but don't buy the "HDTV antenna" hype.
I am hoping that this signal will be a 16:9 HD signal (720P or 1080I) that will be crystal clear on my HDTV via my local HDTV antenna in my attic. Is this accurate?
Again - whether it's HD, digital or anything else, the frequency and the amount of signal/noise ratio you need are the only determining factors. Even with HDTV you will probably still need a signal that's at least 75-100uv above the noise for a noise-free picture.
My attic is on the second floor and does not have any insulation on the roof.
I do have an air conditioner air handler in the attic.
Keep the antenna away from it. Don't even have the antenna "looking over" it. Best is if you can place the antenna so that the AC stuff is behind it.
I need to point the antenna ~ magnetic north since the eight stations I want to pull-in range in degrees from 357 to 3. I am basically looking to 'split the difference'.
Sound good?
Depends on the horizontal beamwidth of the antenna. You need at least 15 degrees. Since most antennas of the type you're looking at are closer to 45 degrees, that shouldn't be a problem.
I have run RG6 QS cable; this will connect my antenna to my Dish Network HD tuner.
Dish TV is at satellite frequencies. The tuner has a discrete "local antenna" input?
The run is ~ 130 feet. What is the max run for RG 6 QS for an antenna run?
130 feet of RG6 has an attenuation of ~8.3db at 500 MHz. That's about 85% of the signal lost. You'd need a decent preamp at the antenna, or 8db more gain at the antenna than you think you need.
Will a Channel Master 4248 eight-bay bow tie antenna (60 mile range) work well
That would depend on the actual antenna gain.
and compensate for the fact that the antenna is in the attic?
If there's no metal on the roof there's nothing to "compensate" for. If there is, nothing can compensate for it.
I am concerned with decibel loss from being inside.
Being behind dry wood? No loss. Being behind shingles? None if theye's nothing metallic in them - more than an antenna can compensate for if there is.
I was considering a Yagi style antenna (directional) but it may be hard to fit.
For channel 2 it'll be about 5 feet across and about the same in length.
Will I comprimise alot with the non-directional Bay Bow Tie antenna?
A channel 2 bow tie? Figure about 12 feet wide and, for 8 elements, 10 feet high - minimum. Small you-can-hold-it-in-two-hands bow tie antennas are for UHF only and, then, aren't that good on the lower (below about 40) channels. A bow tie
element (one "tie") would be about 50" across and close to a foot high for channel 2. And they aren't off-the-shelf antennas.
