glass mounted antenna off vehicle
Acetone and plastic usually don't not play well together (very long)...acetone softens the syringe barrel as well as the rubber end of the plunger...causes plunger to stick to barrel of syrg, i.e. no smooth control while expressing acetone (fingernail polish).
I'm more in favor of WD40 and razor blade (no worries about paint this way)...just use patience and allow solvent to work on newly exposed crease as it creeps down to the newly exposed adhesive. Rock single edged razor blade while keeping sharp edge as close to glass as possible...should leave very little adhesive residue on glass...which is easily removed w/more WD40. Like "hukd on fonix...it werkd 4 me".
tl
Monitoring before scanners...
2 tunables
Pro-77
Pro-30
Pro-2006
Pro-90
BC80XLT
BC760XLT (2)
...and still can't keep up
