Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 06-22-2007, 05:58 PM
BOBRR's Avatar
Default Metal Screen Effect On VHF Listening ?
Hello,
Never thought about this before, but have started wondering.
Good question for all you experts out there.
Live in a typical New England Colonial with a Louvre in the attic on each gable end that are screened to keep the bugs out. Screens are metal.
In the attic I have two VHF antennas for my scanner. A Scantenna and a Discone.
(do listening only)
Was wondering if the metal screens might have any effect on what I can pick up in the more or less horizontal directions ? e.g., P.D.'s from ou,r or a neighboring town.
Probably have no effect for aero comm listening as the received signals are pretty much from a vertical, or near vertical direction.
Should I go to the trouble of replacing them with plastic screens ?
Distance from antennas to the screens is probably about 20 feet or so.
Any thoughts on this ?
Thanks,
B.
Old 06-22-2007, 06:08 PM
DPD1's Avatar
At that distance, I doubt it... Probably wouldn't change anything.
Dave
www.DPDProductions.com
Custom Antennas & Radio Accessories
Old 06-22-2007, 06:50 PM
Smile
Being the "nut-job" I am, I'm now curious if running and attaching a wire from an interior antenna to a metal window screen would actually improve reception? Believe me, there's no length I wouldn't go to for better reception and coverage. Then again, I often wondered what would happen if you could run antenna wire up to a train track, but of course that would be illegal - and just plain WRONG!
After reading the above, again DO notice where I mentioned that I'm a "nut-job!"
Old 06-25-2007, 05:10 PM
kb2vxa's Avatar
Using a railroad track for an antenna has been talked to death and the consensus finally reached is it's less than useless. If it's an electrified line running a wire to the overhead catenary would give some pretty interesting results.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 06-25-2007, 07:08 PM
Smile
Old 06-25-2007, 07:26 PM
blinddog50's Avatar
What I use at work for HF reception on my ats 909.
It runs 600 ft., N. to S. and E. to W.
Works better than a long wire that I use to use.
It's a chain link fence that runs outside my office.
It's well grounded and gets signals that the long wire couldn't snag.
Livin' in the hills, mountain top dx'n.
Old 06-25-2007, 10:52 PM
Raven95150's Avatar
Where I used to live we had a 75 foot steel power pole in the front yard. Out of curiosity I attached a piece of wire to it and my scanner. It got no better reception than with the rubber ducky. Now, if I could have climbed up and put a scantenna on top of that thing.....
KD0AXS
Metro Skywarn #7344
Uniden BCD396T, BC250D, BC350A
RS PRO-84
Yaesu FT-2800M, VX-170
Similar Threads
cant recieve fast food, etc.... frequencys on my BCD996?? coachmenguy General Scanning Forum 34 07-06-2009 02:09 PM
I've been listening to the VHF low band and... KC0UWS Skip / Tropospheric Ducting Forum 2 01-12-2007 01:49 PM
Interoperability: VHF Radios Russell Texas Radio Discussion Forum 4 11-27-2006 10:23 PM
