Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 01-08-2005, 04:00 PM
merlin-7's Avatar
Default #3 discone need input
Ok I did a bit of work today on my home built antenna, I added some 20 inch elements to the cone and some 7 inch elements to the disk.
This should give it a 1/4 wavelength down to about 120 mhz.
I found and old cb base antenna that was, well mangled and used it for parts.
Tell me what you think.
IT has 12 elements on the cone so far, I need to find parts for 4 more however I did balance them out. In other words, there are 4 elements missing 90° apart.
What would you do to change it?
I am looking at the 120 to 870 mhz range...
I am new to this, but it is so fun. even at 43 years old
Old 01-08-2005, 05:19 PM
aluminum + copper = corrosion
corrosion + RF = lots of noise
Tom
Old 01-09-2005, 08:50 AM
TeRayCodA's Avatar
corrosion..get some good enamel spray paint,paint it.
Good work Merlin! you're getting the hang of it!
Old 01-09-2005, 10:37 AM
TeRayCodA's Avatar
Also,if you could use some copper tubing or brass welding rods,you could solder them to the cone,and would make better conductivity,and lessen the chance of corrosion(similar metals)
Old 01-09-2005, 11:17 AM
TeRayCodA's Avatar
I don't know what your spacing is for your insulator,but I always have mine on everything I build at about 1"
Old 01-09-2005, 01:11 PM
merlin-7's Avatar
it is 1/4 inch fiberglass, I have several sheets of it so adding a few more will not be a problem (I just cut out what I need with a hole saw)
Thanks for the input everyone, keep your ideas coming in.
I have off next week so when I get all the ideas in I will take it back down and rebuild it.
I have been playing packrat and looking for old antennas and other building materials. so far the antenna has cost me $14. I want to use just one material for it but its kinda hard to find copper or brass rods really cheap.
I did find about 25 feet of rg-8/u
Thanks again all.
