Go Back   The RadioReference.com Forums > Topic Specific Forums > Antennas and Coax Forum
Antennas and Coax Forum Discussion on the development and implementation of antennas for radio monitoring activities.
Old 02-02-2008, 07:51 PM
Ghost4658's Avatar
Question Larsen NMO150/450/800 & Spring
I got a Larsen NMO150/450/800 antenna and I put a Larsen shock spring on it.
What I need to know is with a shock spring added do I need to trim the bottem of the whip on the antenna to keep it tune.
And if so how much would I need to cut off to keep it in tune?
Old 02-03-2008, 12:02 AM
Send a message via AIM to fineshot1
That info would normally be in the paper doc that comes with the antenna.
fineshot1
NJ USA
Old 02-03-2008, 05:02 AM
I did the same thing with mine and I didn't notice any difference in receive performance on those bands. If you used the antenna for transmit that would be a different story. When I added the spring it made the antenna resonant on the 2 meter and 440mhz ham bands.
Old 02-03-2008, 09:02 AM
Default Shock spring
How long is the antenna?
Old 02-03-2008, 09:52 AM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
The Larsen NMO-150/450/800 is not recommended for transmitting. Adding a spring will cause the center frequencies to skew down. The antenna is 14 inches. I find no reason to put a spring on my antenna.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 02-03-2008, 07:43 PM
Ghost4658's Avatar
I use mine on a 1975 CJ5 jeep in the woods without a spring it would not last very long.
It is working just fine with the spring.
Old 02-03-2008, 07:51 PM
Universaldecoder's Avatar
I have a spring on mine too. The spring itself is grounded, and therefore the spring becomes an extension of the cable's shielding. The actual signal coming from the antenna travels along another cable that runs inside the spring last I looked, and it's been awhile. Bend it and see. Also you can test it with a continuity meter - there should be no transfer of signal from the spring to the center contact.
The spring should not affect the tuning of the antenna as is. If you cut the antenna, then yes you will change the tuning.
Regards,
Josè
"If you can imagine it, it exists in this universe in some form, the difficulty is imagining something that doesn't exist."
Old 02-04-2008, 06:46 PM
Ghost4658's Avatar
We do not recommend putting a Spring on the NMO150/450/800 as it will degrade the performance. If you still want to put the Spring on this antenna you will need to measure the length of the spring and cut that much off the bottom portion of the whip.
Account Manager
Larsen Antennas
Old 02-04-2008, 08:36 PM
Red face
Account Manager
Larsen Antennas
I was wrong! You are right. The spring is not insulated from the center.
Regards,
Josè
Old 02-04-2008, 09:55 PM
Ghost4658's Avatar
I hope this helps you with your ant.
I cut mine today I will let you know if it works better or worse.
Old 02-04-2008, 10:06 PM
Retested it with a meter to make sure. Let me see if I'm right with this one - the reason you want to cut only the length of the antenna is because of the cable that runs inside the spring. It's the shortest route for the signal. If it did not exist, then you would have to cut the length of the spring's coil from the antenna.
Regards,
Josè
Old 02-06-2008, 11:58 PM
Ghost4658's Avatar
The ant is working fine with the spring on 155Mhz & 800Mhz trunk I don't scan many 450Mhz so I don't know about that.
The wire in the center of the spring is to keep the spring from working like a load coal on the ant.
Old 02-07-2008, 10:25 AM
rfradioconsult's Avatar
The spring itself is not grounded but is part of the design of the radiator. The purpose is to keep the spring from acting as a loading coil and changing the electrical length of the antenna. Even the old spring found on low band quarter wavelength antennas contain this braid. If you had a customer with antenna issues this was one of the first things that was checked.
T
Similar Threads
Larsen NMO150/450/800, where to buy... CLTX11 Antennas and Coax Forum 25 07-07-2008 01:53 PM
Larsen antennas morganod Old Classifieds Archives 0 04-08-2007 05:35 AM
Scan-Wis Spring Meeting - 4/9/06 - Brown Deer vivavegas Wisconsin Radio Discussion Forum 0 04-05-2006 08:44 AM
Larsen NMO150/450/800 JackVO Antennas and Coax Forum 4 02-11-2006 07:25 PM
162.475 in Silver Spring, MD ???? JamesO Maryland Radio Discussion Forum 2 07-28-2004 12:06 PM
