| AOR Receivers A forum for the discussion of all AOR scanning radios and receivers. |
03-18-2013, 4:32 PM
AR82 00MK3 USB Cable from the 'Bay
I recently stepped up from an AlincoX10K(unblocked) wide range receiver
to the AoR 8200MK3-G- version..
First big YIKES that hit me was the cost of support/expansion gear..long story to short
I kept looking for a few weeks on the bay,maybe a used cable would find its way on there..
None to be found...
Then this one pops up from the UK...
AOR AR8200 USB Computer Control Cable Similar to CC8200 | eBay
I order up..about a fortnight passes and on Saturday afternoon USPS drops it in my box.
Im using the free JAVA app for programming but I will Confirm that the cable will Up/Download with ease,im running XPPro SP3..I did Not install the drivers,it was true plug n play..
Thumbs Up from me.And it was about half what the OEM unit runs for...
>>>AR8200MKIII-DJG5-PRO106-PSR310-PSR800<<<
03-19-2013, 1:17 AM
Every once in a while a HP Jornada cable pops up at the Goodwill store here ,the only catch is that some of the cables have a pin tied to ground and that needs to be cut sometimes, but the connectors are the same.
If you want to tap the discriminator, make an interface or a Scout cable get one or order one from AOR.
David Kb7uns
AR3k,AR5k,AR8k,AR82k,AR86k,SDU5k,SDU55k,ARD25 R10,R20,R71,R72,R75,R7k,R71k,R85k, PCR1k,PCR25k,R2500 PSR500,PSR600,PSR800 RS26,94,97,2035,2055,106,197 760xlt,245XLT, 796D,996T,996XT,396T,396XT,HP1,HP1E
03-19-2013, 11:04 AM
thanks
found one on amazon used 11.00 plus shipping cost me 15 bucks great deal save me a ton of money on Radio Referance
03-20-2013, 3:41 PM
You must still wire the cable up to a MAX232 chip or some other level converter, but if you are like me I have half a dozen around here including the old AR8000 cloning/RS232 interface that will work.
Not sure if he still has some but I got some from Taka down in Torrance a few years ago.
David Kb7uns
03-21-2013, 2:22 AM
Here is the pinout for the intterface jack.
David Kb7uns
03-21-2013, 7:14 PM
Oh Brother..You Rock..
Worst thing is not having the pinouts and that slim margin of i was wrong and bricked my radio..
Thanks man!
03-22-2013, 9:56 PM
thanks for the help DKF435 unfortunly what i ressieved was not the right connector so back to the seach i will save the pin out.
03-28-2013, 11:48 PM
What connector did you get?
