Wondering if anyone else with AR5000A using OmniRig radio control interface is getting a popping or pulse from the RS232 connection? Every time its activated I hear the popping and it only happens with OmniRig. I have One or two other applications that don't use omnirig and all seems fine. This popping effects everything, can see on meter, spectrum display, and hear it.
The popping seems to be related to the Poll Int, ms. I can adjust this setting and the popping increases or slows now but cant make it go away.
I already tried 2 Pcs with same results, I will see what I can do for better grounding but cant go crazy not perm setup for radios.
Anyone gets this also or have any suggestions to get rid of it!
