All-Modes
Greetings.....
I'm having problems replacing the internal lithium battery in my AOR3000A.
I've removed the two-piece circular black plastic cover with a hole in its top-side which (I think...) holds the battery against two metal prongs soldered to the PCB behind the board holding the operating buttons for the receiver.
The "prongs" go through two holes at the bottom of the circular plastic holder - resting against the bottom of the CR 2032 battery - which can be removed by separating the two halves of the plastic holder.
My problem is that I thought the two metal "prongs" needed to be soldered to the battery - but there are no signs this was done in the case of the existing battery - I also can't see how this could be done.
(The scanner's memory was fine (and the battery working) until I left it unplugged and stored in a cupboad for a couple of years - after which the receiver would not power-up)
Now, assuming I have indeed removed the battery cover and not some other component, how do I re-attach the two-part plastic battery cover (with the new battery inserted) back onto the PCB? It was hard to pull-off the board and will some-how to be stuck back-on the PCB. Usng tape? Glue?
I've a horrible feeling I might have removed the wrong component....if so, what is the two-piece black plastic "holder" for?
Could someone please give me step-by-step instructoins for replacing the internal battery - including giving confirmation of where it is located on the PCB?
I've read earlier Forum postings on eplacing the battery - but am stil confused.
I'd also like to know - one way or the other - if the two-part black plastic "container" I've removed is the battery holder.
Hope this garbled account makes some kind of sense - I can't undrstand why AOR have made replacing a battery with a finite life so hard....and why the receiver handbook handbook doesn't make clear hiw to do it..
Any help/advice gratefully received.
Many thanks.
All Modes (Pete)
Many thanks.
All Modes (Pete)
