Hello,
Scott noticed problems with the 15KHz bandwidth on the previous firmware version. I did as well. The current version does not fix this. Please pass this information on to AOR.
I decided to run some quick bandwidth tests by feeding a 20 MHz S9 signal into the DV1 receiver. I verified the output was clean using my AR-Alpha in parallel. I used the S Meter indication on the DV1, which is a rough measure. I tuned the receiver rather than the generator. I did not test all the filters.
Some filter bandwidths have serious problems.
200 Hz filter looks okay.
Code:
CW 200 Hz 10 Hz Steps
19999.89 S1
19999.90 S3
19999.91 S7
20000.00 S7
20000.10 S7
20000.11 S5
20000.12 S1
500 Hz filter looks okay.
Code:
CW 500 Hz 10 Hz steps
19999.74 S5
19999.75 S7
19999.76 S9
20000.00 S9
20000.25 S9
20000.26 S7
20000.27 S5
The 1.8 KHz SSB filter is offset for sideband and looks good.
Code:
USB 1.8KHz 100 Hz Steps
19998.1 S5
19998.2 S9
19999.8 S9
19999.9 S7
The 2.6 KHz SSBfilter is offset for sideband and looks good.
Code:
USB 2.6KHz 100 Hz Steps
19997.3 S5
19997.4 S9
19999.8 S9
19999.9 S7
3.8 KHz AM filter looks more like 3 KHz bandwidth.
Code:
AM 3.8KHz 100 Hz Steps
19998.3 S3
19998.4 S5
19998.5 S7
19998.6 S7
19998.7 S9
20000.0 S9
20001.3 S9
20001.4 S7
20001.5 S7
20001.6 S5
20001.7 S3
5.5 KHz AM filter looks more like 15 KHz bandwidth.
Code:
AM 5.5KHz 100 Hz Steps
19992.3 S3
19992.4 S5
19992.5 S7
19992.6 S7
19992.7 S9
20000.0 S9
20007.3 S9
20007.4 S7
20007.5 S7
20007.6 S5
20007.7 S3
The 8 KHz AM filter has serious problems with a bandwidth of about 15 KHz and spurious responses around +/- 31 KHz from the receive frequency.
Code:
AM 8.0KHz 100 Hz Steps
19966.2 S3
19966.6 S3
19966.7 S5
19967.3 S5
19967.4 S7
19968.7 S7
19968.8 S9
19968.9 S7
19969.1 S7
19969.2 S5
19969.3 S3
19969.4 Noise
19992.2 Noise
19992.3 S3
19992.4 S5
19992.5 S7
19992.6 S7
19992.7 S9
20000.0 S9
20007.3 S9
20007.4 S7
20007.5 S7
20007.6 S5
20007.7 S3
20007.8 Noise
20030.7 Noise
20030.8 S5
20030.9 S7
20032.6 S7
20032.7 S5
20033.3 S5
20033.4 S3
20033.8 S3
The 15 KHz AM filter has serious problems with a bandwidth of about 30 KHz and spurious responses around +/- 31 KHz from the receive frequency.
Code:
AM 15.0KHz 1KHz Steps
19947 S9
19976 S9
19977 Noise
19984 Noise
19985 S7
19986 S9
20000 S9
20014 S9
20015 S7
20016 Noise
20023 Noise
20024 S9
20053 S9
The 6 KHz FM filter appears to be around 15 KHz bandwidth. I did not note any spurious responses.
Code:
FM 6 KHz 100 Hz Steps
19992.4 S5
19992.5 S7
19992.6 S7
19992.7 S9
20000.0 S9
20007.3 S9
20007.4 S7
20007.5 S7
20007.6 S5
The 15 KHz FM filter has serious problem with spurious responses about +/- 31 KHz from the receive frequency. The bandwidth looks okay.
Code:
FM 15KHz 1KHz Steps
19966 S1
19967 S5
19968 S7
19969 S7
19970 Noise
19993 S9
20000 S9
20007 S9
20008 Noise
20030 Noise
20031 S7
20032 S7
20033 S5
20034 S1
The 30 KHz FM filter appears to be around 70 KHz bandwidth.
Code:
FM 30 KHz 1KHz Steps
19957 S3
19958 S3
19959 S5
19961 S5
19962 S7
19968 S7
19969 S9
20000 S9
20031 S9
20032 S7
20038 S7
20039 S5
20041 S5
20042 S3
20043 S3
73 Eric
