MStep
Some of these issues were reported in other threads, so they existed prior to the v1512D firmware upgrade. Others may have been fixed in either this upgrade or previous upgrades, but at least on my unit, with the 1512D upgrade, they continue to exist. Others may not have been corrected in firmware upgrades, but I have seen mention of them in other posts. Let me cover some of my main concerns, and perhaps others who have the DV1 can experiment and comment.
1- There is a noticeable difference in audio quality on FM signals between the "AUTO" mode and the "FM" mode, even when all other factors (bandwidth, etc) remain the same. AUTO mode sounds great; FM mode does not sound nearly as good--- it sounds like there is much more treble. One would think that audio quality would be identical, but for some reason, it is not. This is very easy to test. Simply program in your local NOAA weather frequency and while listening, switch between Auto and FM mode. You'll notice quite a difference in the quality of the sound.
2- The CTCSS mode is still quirky, and this is very noticeable in "SEARCH" mode. While listening to some FM traffic (in either Auto or FM mode) at 15 khz, bandwidth, I've switched on the CTCSS search mode and the radio not only would not detect the proper CTCSS tone, but it also muted the audio for the signal I was listening too. This does not happen all the time. You can also test this on your local NOAA weather channel. While listening to NOAA, turn Squelch (Func-1) to CTC and then turn CTCSS to "Search". Hit Enter and you will see that the audio on NOAA almost drops out completely, with a few spotty words being heard now and then. I also tried this with some of the local ham radio repeaters as well with the same effect.. Yet on some other channels, it seems to work properly. I changed all of the other squelch settings (Auto, LSQ, NSQ, Voice Squelch), and nothing seems to change the condition. Once you turn the squelch setting in Func-1 to OFF, you will once again hear station audio.
3- Speaking of Squelch modes, the DV1 seems to have an number of them, and while the manual explains how to implement them, it does not really explain the differences in operation. There is LSQ, NSQ, Auto and Voice Squelch. In section 4-7 of the operating manual, it gives detailed information on implementing the Voice Squelch function, but it terms of what it is supposed to do, all it says is, "When the voice squelch function is activated, the audio will be muted on unwanted voice signals." I wish someone could explain to me what that means, because when I activate the function, I see no difference in the operation of the radio.
There are some other anomolies, but for right now, the above three items are my main concerns. I agree completely with Steve Sherman's assessment that if you are in an AM broadcast station RF saturated environment, as either he is or I am, some type of preselector is going to be needed for adequate reception from 1.6 - 30 MHz.
Overall, I like the feel of the radio, and the display is tolerable. DMR, P25 and NXDN reception is good--- I haven't copied any other digital modes yet.
It's nice to have a "tuning knob" at my disposal once again--- given the size of the radio, it's a little small, but I got used to it pretty quickly and it's very functional.
I like the radio. I hope others who have the unit, will take the time to experiment with items # 1 and 2 above and report back here with their observations.
And if someone can explain to me the differences in the various squelch modes, particularly pertaining to Voice Squelch, it would be greatly appreciated. The manual's explanation, that "When the voice squelch function is activated, the audio will be muted on unwanted voice signals." has me completely baffled.
