The 8600 Mk 2 has an ACC connector (8 Pin Mini Din) at the rear. According to the manual addendum Pins 6 & 7 provides squelch controlled audio output. I purchased a cable with one end an 8 Pin Mini Din and the other end was a free end with 9 free cables (not 8). The cable appears to have 2 'black' cables (I guess that's a 'shield')? I have connected Pins 6 and 8 to a 3.5mm connector that plugs into my PC's Line-In or Mic socket (I believe it correct to use the Line-In)? But the audio from the 8600 that comes out of the PC speakers is ok but all transmissions end with a 2-second dying hissing sound. I'm trying to decode ACARS data but can't get it to work because I believe the cable isn't made up right? Anyone made up their own before or know how to do it--what am I doing wrong here with the cable?
** picture/diagram of cable attached to this message as .PDF file **
Thanks in advance ...
