Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 04-21-2017, 2:20 PM
AlphaFive's Avatar
Default DV1 coverage breaks
Referring to the DV 1, although I see the coverage is listed as 100 KHz. to 1300 Mhz, are there coverage breaks? Specifically, most, not all, scanner radios will stop at 54.00 and pick back up in the 70's or at 108 Mhz. Will this receiver go through 54.00 to 108.000 Mhz.? I cannot locate anything that says there are breaks in the band coverage.
If so, kudo's to the DV 1. Thanks for your help, Lance
I'm aware of the cellular breaks, not an issue..
"I am serious, and don't call me Shirley" - Dr. Rumack 1980
Pace 1000B Pro 2020 Pro 34 Pro 94 Pro 197 BCD536HP TRX 2
Old 04-21-2017, 4:09 PM
Default Coverage
No breaks, full coverage.
That is subject to locality though. You say you are aware of the Cellular frequency blocking in the U.S.
An AR-DV1 for the U.K. market has no restrictions for example. Every frequency from 100 KHz. to 1300 Mhz with no 'jumps'.
Cheers
Old 04-21-2017, 4:15 PM
AlphaFive's Avatar
Default Coverage breaks
Thank you Sir, that is fantastic, take care
Old 04-25-2017, 12:37 PM
F5HPE's Avatar
Depending on the country, i.e. like in US as Cellular Blocked, some other contries are also locked due to national regulation.
