Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > AOR Receivers
AOR Receivers - A forum for the discussion of all AOR scanning radios and receivers.
Old 12-06-2017, 3:19 PM
safetypro79's Avatar
Question AOR 3030 Filter question
Anyone know where to obtain the Rockwell/ Collins filters for the 3030 ?
Yes checked on eBay none out there... I know Rockwell stoped mechanical filter production in 2016, so they may not be obtainable anymore.
73
John
Old 12-06-2017, 9:04 PM
dkf435's Avatar
Which filter?
CW on there right now 526-8634-010
David
https://www.ebay.com/itm/526-8634-01...AAAOSwbtNaAFO9
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25R1,10 ,20,71,72,75,7000,7100,8500,PC/R100,1000,2500 PSR500,600,800,PRO668,2035,96,106,BC760,796,996T,9 96XT,396T,396XT,HP1,HP2,436HP,536HP,WH-TRX1
Old 12-06-2017, 9:34 PM
Thumbs up Thx
I will keep looking probably both the am 6 kHz and the SSB 2.5 khz
Old 12-06-2017, 10:39 PM
dkf435's Avatar
Is the 6kHz not already in there? The Universal Radio page says the 6kHz AM is supplied and only shows the 2500 and 500 Hz as optional.
David
Look at this one also they spec the low cost plastic case ones for the AR5000 and this may work.
https://www.ebay.com/itm/ROCKWELLCOL...4383.l4275.c10
In the update for the AR3030 they list these filters
AM filter 526 8636 010 or 526 8695 010
SSB filter (option) 526 8635 010 or 526 8694 010
CW filter (option) 526 8634 010 or 526 8693 010
http://pdf.textfiles.com/manuals/SCA...20Addendum.pdf
Old 12-07-2017, 5:43 PM
Arrow Yes does have
The standard 6 kHz. I would need the 2500 kHz
73
John
Old 12-08-2017, 3:33 PM
dkf435's Avatar
Look at this one
https://www.ebay.com/itm/ROCKWELLCOL...8AAOSwJ4hY93Ev
David
Old 12-08-2017, 5:36 PM
Thumbs up Thanks David !
That looks to be correct a 3 pole, 2.5 kHz
73
john
