| AOR Scanners A forum for the discussion of all AOR scanning radios and receivers. |
08-23-2008, 06:26 PM
AR-3000A power connector
Greetings, my AR-3000A needs a new power plug (never got the original one) but the socket seems special. At the moment I am using two separate core-less tube-like ends pulled of a standard PC component power connector. Fits very well actually, but I am not looking forward the day when I will swap them wrong way around. Is there anything else using the same 3-pin connector I can fish it out from? I was thinking of replacing the socket completely but...
Jan
08-23-2008, 07:17 PM
AR300a power
A couple of options...
A)I believe that the early 1200-2400 baud hayes modems used the same connector. Find one of the p/s, cut off the connector and splice it in. If I remember correctly, they were in black extruded cases.
B) just remove the AR's factory connector, replace with a standard coaxial connector. Cut up a small piece of aluminum, mount with the two factory mount holes, drill a hole in the middle for the coaxial connector.
I've done both before (several of the Mxxxx series scanners used the same connector (they were made by AOR)
tom
12-26-2008, 10:36 PM
Found one of the modems and investigated where is the power supply, then I got it -THANKS!
Yesterday I have finally used it, and also modified radio's antenna connector to Ntype.
01-01-2009, 04:05 AM
Parts for AR3000/A
rfrobins on ebay sell kits with case, controls,knobs, power cable and rear connectors for the AR3000/A radios just keep checking his auctions and they pop up
David
01-26-2009, 09:12 PM
How difficult was the N connector modification? Did you have to enlarge the chassis hole? I do not recall seeing available a chassis mount N connector that would fit without some drilling...pictures perhaps?
Henry, KK4HG
01-26-2009, 09:14 PM
Sorry, I am idiot...just saw your earlier post with great pics...thx!
Henry, KK4HG
01-26-2009, 11:55 PM
No worries, all I did was removing all the main boards, then wrapping the front panel circuits with piece of plastic and duck tape. To enlarge the connector hole, I have used round file.
Good luck with your modification!
We need PSION back.
Jan
01-27-2009, 12:01 AM
Thanks, Jan. I am off tomorrrow to find a chassis mount N connector.
