Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > AOR Scanners
AOR Scanners A forum for the discussion of all AOR scanning radios and receivers.
Old 06-12-2009, 11:13 AM
hardtstein's Avatar
Default pc cable for AOR AR16?
Looking for the pc cable for the AOR AR16 or a diagram to make one Thanks.
Old 06-12-2009, 09:26 PM
Default Aor ar16
Sir
I have the info somewhere at work, will try to get it posted first of the week.
If I remember correctly, it has 3.3-3.5 v ttl signals, so you will need a ttl-rs232 converter ( several of the maxim products will do) that is 3.3 volt compatable, some of the 5volt ic's don't switch well @ 3.3v
I'll try to get the data up later...
tom
Old 06-24-2009, 03:53 PM
Default AOR AR16 interface
The serial connector is a 1/8 stereo connector, tip= RX data to radio, ring= TX data from radio, sleeve= gnd. As I referenced earlier, the internal supply is nominally 3.3 volts, so you will need a TTL (3.3v) to RS323 converter. I have used a maxim part (they have several that will work with 3.3v), you just need 1 TX and 1 and one RX channel. Their data sheets should provide basic hook-up information. Depending on the device you use, you may have to provide an external supply to run the converter if you can't get enough power from the serial port.
good luck
tom
Similar Threads
BC898T PC Cable and Demo Software Problems Solved tetralite Uniden Scanners 0 04-11-2009 08:36 PM
PC Interface Cable Thumper2u Old Classifieds Archives 6 03-10-2009 07:54 PM
Need Pc Serial cable for BC250D LarryMax Old Classifieds Archives 7 09-07-2008 02:41 PM
GRE PC Data Cable Software thumper26 Radio Shack Scanners 3 07-22-2008 11:47 PM
396T Scanner to PC Cable firemedic7526 Old Classifieds Archives 2 06-08-2007 12:35 AM
