Hi,let me clear up ,serial ports are communication ports and RS232 are the specifications set as a standard for use of this port (which pin used for xmit and rec pins, ground and power pins etc).On my toshiba A60 had a PCMCIA port and I found a adapter that supplied a serial that met the RS232C specs,
(PCMCIA - serial port).Now the laptops seem to only have USB ports ???. The only thing I can suggest is to find a USB to Serial Port adapter (that say the serial port meets thr RS232 spec.) Just this past month I ran into a problem with the USB port,I have one of those digital photo converter,wouldn't work with the laptop.I e-mail the manufactor and they told me that most laptops don't supply enough current for it to work.I just got a emachine tower and the digital photo converter worked (tower supply enough current for the USB port).Ray
PS I just got a serial port card for my emachine tower .
