Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > AOR Scanners
AOR Scanners A forum for the discussion of all AOR scanning radios and receivers.
Old 09-25-2009, 07:43 AM
Default 3ghz reciever
hey you guys that own the ar8200 or similar radio that receive up to 3ghz, i want to know what is up there between 1.296 - 3ghz to listen to? i know theres 2.4 ham that you might be able to hear analog cw/fm but im guessing everything else is digital crap right?
website: http://kd8eyf.org
Old 09-25-2009, 10:07 PM
To be honest very little, I have an Icom R20 and have never heard much above the 800MHz trunking band.
Paul
Old 10-01-2009, 10:32 PM
I also own the aor 8200 mk3 and very rarely do I go to any of the higher frequencies due to not hearing anything there. Anyone have any suggestions as to what can be heard on those higher frequencies?
Old 10-02-2009, 09:15 AM
There really isn't much that's actually listenable above about 960 MHz. There's some amateur repeaters on the 1200 band (closer to 1300, really), and at 2304 some weak signal ssb and cw amateur activity, but that's going to be sparse and difficult to capture with a consumer grade receiver. There may still be some analog marine satellite activity around 1500 MHz, but I understand that's going away to digital modes. I really don't know why the manufacturers bother covering beyond 1300 MHz at all... it's a waste of time and money.
12 volt radios are for wimps. Real radios can kill you.
Old 10-02-2009, 09:29 AM
https://www.fbo.gov/index?tab=docume...bbb1ab3ffdb392
will give you an idea of what the FBI is up to between 1.755 and 2.4 GHz, and higher.
Old 10-02-2009, 11:39 PM
satob1's Avatar
Send a message via AIM to satob1 Send a message via MSN to satob1 Send a message via Yahoo to satob1
Smile an icom r9500
hi guys a icom r9500 coms receiver there upto $19000aus or $17000us im not sure how much theyre in the usa but they look nice ,thanks hamguy2 nsw australia
Old 10-02-2009, 11:42 PM
satob1's Avatar
Cool he have civil; aviation feeds on scpc via satellite
hi there ,we have civil aviation feeds for aircraft australia wide via satellite the satellite is optus d1 at 160east ok .but with any scanner and a interface hooked into a splitter you can hear aircraft anywhere freq 12.250 to 12.750fmn ,thanks hamguy2 nsw australia
Old 10-04-2009, 12:14 AM
I'm not sure what we're supposed to see with that link, but I sure didn't see much of interest.
1755 Mhz is within the Federal point to point band, so it's likely that signals there are going to be multiplexed, possibly digital. It could still be wbfm with ssb subcarriers on it. That could be demodulated, but is probably beyond the capability of most people.
Old 10-04-2009, 01:42 AM
satob1's Avatar
Default fbi etc police
hi our police here are on 468 mhz here apco25 fully encrypted also there are police up the hunter valley from me that are on 78mhz analog fmn ,our federal police are on 480mhz and up i believe .also about the fbi i assume that the fbi signals are encrypted that high up i guess theres also police freqs here on 4mhz ssb im not sure if there encrypted but i know the power is 400watts anyway ,thanks hamguy nsw australia
Old 10-04-2009, 01:52 AM
satob1's Avatar
Cool aor scanner and icomr20
i have a aor 8000 i got from the usa a few weeks ago its unbelievable what functions it has. im also trying to get an aor3000 400channel scanner which were so expensive here to buy in australia ,you look at the aor 5000 etc here there i think there over$2000a the 8600mk2 is $1149aus or about$1000us ok .also the icom r20 ive never played with but there like the current model the prices on them are between $700 and $817a. if you want to look at the prices of how much australian people get charged for things new and used check out Andrews Communications also Icom | Yaesu | Kenwood | Diamond | Cushcraft | Strictly Ham Australia's Largest Amateur Radio Dealer! ,thanks david nsw australia .
Old 10-04-2009, 09:35 AM
Try: https://www.fbo.gov/index?s=opportun...=core&_cview=1
It's the Solicitation 1 - RF RFP 090415 pdf located at the upper right corner.
Old 10-04-2009, 01:14 PM
Ok. That's much more interesting than the previous link.
It boils down, however, that it's not likely to be something that could be received with a consumer grade wideband receiver. There's a ton of signals up there, and nothing to listen to.
