Originally Posted by rayzor_uk
will go further into it carnt do no harm aslong has i put it back has it was
cheers
You are wrong. At present according to your post the display is offset by 10KHz. It's not difficult to adjust your working to accomodate this. If you start adjusting the alignment it is extremely unliikely that you will get it back to the original correct alignment without the correct equipment.
If you just start to adjust things then you are likley to end up with a totally useless radio and highly unlikley to be able to adjust back to your pre-meddling state.
Your money and your choice of course.
