Go Back   The RadioReference.com Forums > Scanners and Receivers Forums > AOR Scanners
AOR Scanners A forum for the discussion of all AOR scanning radios and receivers.
Old 02-13-2008, 05:52 PM
Lightbulb P25-8600 APCO25 Decoder & AR8600MKII
Greetings everyone:
Can someone explain is there any further requirments once the P25-8600 APCO25 Decoder board is installed to have it fully functional? I've got coming the scanner and the board to decode.
Secondly, what does a scrambled signal sound like? is it similar intermod distortion?
Jason
Old 02-13-2008, 06:06 PM
BaLa's Avatar
Send a message via ICQ to BaLa Send a message via Yahoo to BaLa
P25 Encryption?
I think there are a few different kinds..
The kind I'm used to sounds like this
http://www.megaupload.com/?d=KP78WVMY
VFB Stuttgart Deutscher Meister 2006/2007
Uniden BCD396T
RS Pro 92(b), 95, 96
Kenwood TK-280 (146-174MHz)
Old 02-13-2008, 06:15 PM
Exclamation P25-8600 APCO25 Decoder
True,
the APCO25 is just another encyption project, I think. Donte quote me on that. Interesting file, thank you. it'd be interesting to tap into the local police where I am as they have gone to this particular type of system, from what I'm told.
Old 02-13-2008, 06:21 PM
BaLa's Avatar
P25/APCO25 is not encryption
P25 is a digital format.(surely somebody will correct me on this).
I believe there are a few types of encryption that can be used.
I'm not familiar with your particular scanner, with the board it should be able to decode unencrypted P25.
Uniden BCD396T
Old 02-13-2008, 06:26 PM
n2mdk's Avatar
APCO-25 is not any form of encryption it's a form of modulation. Encryption can be used over any type of modulation, but you can't listen to it.
APCO-25 should sound like this without the APCO board installed, http://kb9ukd.com/digital/astro-imbe.wav although that from a trunked system which the AOR can't track it can receive the frequencies conventionally
Jerri
VX-5
FT-60R
Pro-97
BC246T
BC780XLT
BR330T
BCT15
Grundig Satellit 700
Old 02-13-2008, 07:28 PM
frankh's Avatar
Location: Windsor, Ontario..... on the edge of Sanity, 9 miles south of 8 mile
sounds very similar to voice inversion scrambling(if you have a p25 capable scanner) http://www.kb9ukd.com/digital/
Old 02-13-2008, 10:18 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Primarily an AOR question so moved to the AOR forum.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Similar Threads
Active Military frqs. in Colorado Springs Mick Colorado Radio Discussion Forum 46 01-13-2009 08:24 AM
Share Your Fed Logs MACKBOLAN05 Federal Monitoring Forum 0 06-13-2007 03:19 PM
Common Fed Freqs mike_s104 Federal Monitoring Forum 63 04-23-2007 11:39 AM
ARD25 APCO25 digital decoder??? gregmoss AOR Scanners 1 03-17-2007 03:35 PM
ARD25 Apco25 decoder & scanning problem... Mike_Alpha Project 25 Technologies 10 07-14-2004 03:04 PM
