Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum Forum for discussing Radio Information in the State of Arizona.
Old 05-23-2009, 12:53 AM
Astrak's Avatar
Default Somebody want to tell me if this is working
Try connecting to http://192.168.1.4:1175/ in Windows media player. It's just MCSO right now but I want to make sure it's working. For some reason Windows media player doesn't let you connect in a pocket PC. It's ten now I'll leave it up till the batteries go dead.
Maricopa county law enforcement feed
Old 05-23-2009, 01:15 AM
C138Kaysone's Avatar
Send a message via ICQ to C138Kaysone Send a message via AIM to C138Kaysone Send a message via MSN to C138Kaysone Send a message via Yahoo to C138Kaysone Send a message via Skype™ to C138Kaysone
what are you streaming? ill make a little test run
If your thinking too much... smoke will start coming out of your ears... that means your burning up your brain with nonsense.. stop thinking and just DO IT!
Old 05-23-2009, 01:16 AM
Astrak's Avatar
Maricopa county sheriffs office.
Old 05-23-2009, 01:18 AM
ok i never done this on my WMP, exactly where would i go and put in the address you gave?
Old 05-23-2009, 01:19 AM
davidmc36's Avatar
Couldn't get nothing from here. Says "Network Error"
No Bounce, No Play.
The one who dies with the most toys wins!
Personal Weather Station
Astrak's Avatar
File/OpenURL and then enter that address.
Old 05-23-2009, 01:22 AM
yeah im going to give up lol, my WMP is complicated, never used it often.
Old 05-23-2009, 01:28 AM
n5ims's Avatar
192.168.x.x are internal only IP addresses and will only be addressable in your own internal network (behind your own router), not through the internet. For this to be available, you'll need to open a port (1175 from your sample) in your router and route that to the necessary PC (192.168.1.4 in your sample). You'll then need to discover the internet accessable IP address for your router (WAN port, most likely) and have users reach you through that address.
Old 05-23-2009, 01:35 AM
Astrak's Avatar
That's what I figured, finally got the phone hooked up and yeah it was a network error, I kinda figured that was what was happening. Okay more tinkering till I figure it out, so Windows media encoder isn't a good one to do streaming with?
Old 05-23-2009, 01:37 AM
are you trying to broadcast this on IBN too?
Old 05-23-2009, 01:50 AM
Astrak's Avatar
Not that I'm aware of.
Old 05-23-2009, 04:14 AM
Astrak's Avatar
I wish someone would just come out with something that made streaming as easy as just DL a program hook a scanner to comp and there you go...I guess this really doesn't belong in the AZ forum, so move if necessary.
I definitely need some help on setting up a stream...if anyone has some advice I'd take it.
Old 05-23-2009, 11:49 AM
cellphone's Avatar
Hi Aaron,
If you are able to listen to your stream on another computer on your network using the address http://192.168.1.4:1175/, then you are half way there.
You will then need to set up port forwarding in your router for port 1175 to IP address 192.168.1.4. Most routers will not let you port forward to a DHCP address, so 192.168.1.4 (or a different 192.168.1.x address) will likely need to be hardcoded on your streaming machine if it is not already.
If you can send me the model of your router, then I can help with setting up port forwarding.
After that is done, then you will need know external IP address that other will use to connect to your stream. This can be found by going to this link:
Find IP Address: What is My IP Address? IP Address Lookup & IP Locator
I have Cox in Phoenix and my external IP address is 68.104.xxx.xxx, so the external link for this stream will be http://68.104.xxx.xxx:1175/.
After you have the port forwarding done, and have identified your external IP address, then you should be set.
Good Luck.
--Joe
Old 05-23-2009, 03:26 PM
davidmc36's Avatar
One thing that I would add is that if you have a static IP address with your provider the address to your stream will never change. In my situation I have a Dynamic External IP address, assigned by my provider. Every two weeks or so it will change. I overcome this by using no-ip.org. That app/service redirects traffic to your modem/router even if your provider changes it. A little app runs on your computer and checks your IP on a certain schedule and updates as neccessary.
No Bounce, No Play.
Old 05-24-2009, 02:30 PM
Astrak's Avatar
Okay guys try it now, it's MCSO and DPS. You can use winamp or windows media player and open a URL then enter http://72.201.237.21:2634/stream.mp3
Old 05-24-2009, 03:29 PM
davidmc36's Avatar
Not sure if it is something I am doing or not but it tries to start for about one second and then says END OF PLAY.
No Bounce, No Play.
Old 05-24-2009, 03:37 PM
N_Jay's Avatar
seems to be working for me.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 05-24-2009, 04:07 PM
davidmc36's Avatar
Works good for me now too that it has been edited to an MP3. Did not work as an OGG.
No Bounce, No Play.
Old 05-24-2009, 04:13 PM
Astrak's Avatar
Cool, well now if I can just get my phone to work. Windows media player keeps telling me it's an invalid file type...I know it's not but this is a beta version of windows 6.5 so there might be something wrong there.
Old 05-24-2009, 04:21 PM
wlmr's Avatar
Getting the same message using Windows Mobile 6.1. Ok on my desktop PC.
Similar Threads
BCC Rescue 1, Montg, toneouts not working bradam2001 Maryland Radio Discussion Forum 2 08-18-2007 11:37 AM
ISO: Old School Working HF Rig... DewAddict Old Classifieds Archives 0 06-25-2007 08:18 PM
Clark Co FD has working 2 Alarm Fire TOUGHLIFE Nevada Radio Discussion Forum 10 05-10-2007 09:54 PM
Clark Co FD A Working Fire TOUGHLIFE Nevada Radio Discussion Forum 2 04-08-2007 10:20 AM
Anyone listening to ZS6CCY (S. Africa) working North America on 14.191 USB? racin06 HF/MW/LW General Discussion 8 12-25-2005 04:22 PM
