Originally Posted by InlandAZ
Gotcha -
So... one last question... The pro-106 ought to be able to receive them, can they be coded as conventional FM frequencies?
I loaded them into the Chandler scan list, but they're just static noise when they're active.
Ensure the radio is set for digital reception, but the inputs that you are hearing may not be close enough to you to decode the signals. They are not high power, since they only need to make it to a repeater tower.
You probably won't gain any benefit from monitoring these, unless of course that is all you have plugged into the scanner. But, aside from the sparse, one-sided traffic that you'll hear, if you do this, it is only going to be useful to tell you that a unit is nearby to you.
