WLMR was right after all. It was the scanner. I think the problem started when I moved the scanner from the truck. I power the scanner via a DC mobile adapter in the truck. Then when I turn the key off, the batteries kick in. I then plugged my AC adapter into the scanner while it was powered via batteries. This is when I think the problem started. I have never had a problem doing this, but it isn't following best practices. The scanner should always be powered off before changing power sources. A lesson learned.
Anyway, I fixed the problem by turning the scanner off. Removing AC adapter and then removing the batteries. Then I put everything back together and turned the scanner back on using the AC adapter. Problem fixed.
Don't open your mind so far that your brains fall out.
