Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum Forum for discussing Radio Information in the State of Arizona.
Old 10-24-2009, 04:09 PM
cellphone's Avatar
Default RWC Radio IDs
For those of you that have radio ID feature on your scanners, or monitor systems with trunking software, I am seeing a pattern in the radio IDs Phoenix dispatch consoles on the RWC.
The radio console IDs seem to follow this format:
If the talkgroup is 1234, then the console radio ID will be 1xx234 where xx is a station number. Here are some real examples:
Talkgroup A04 South= 2996. Console IDs = 200996, 201996, 202996, 203996, 204996, etc.
Talkgroup C04 South HOT= 2964. Console IDs = 200964, 201964, 202964, 203964, 204964, etc.
Talkgroup C08 Southwest HOT = 2960. Console IDs = 200690, 201960, 202960, 203960, 204690, etc.
Mesa seems to follow the same numbering convention:
Talkgroup A01 Dobson = 3000. Console ID = 301000.
Talkgroup A02 Central = 3003. Console ID = 302003.
Old 10-25-2009, 04:52 PM
FLANO's Avatar
AZ DB Administrator
If you have more examples of this, perhaps you can make this a wiki item under the RWC?
John
SE of Tucson
Old 10-25-2009, 06:40 PM
Astrak's Avatar
I've noticed this only on Phoenix PD, Mesa and Gilbert. Apache Junction does not seem to do this, neither does Tempe. On a side not for those with newer GRE/RS scanners with RadioID's when the man down button is pressed on a radio a radio ID of 0 is broadcast. I have my scanner set to alert when it sees a radio ID of 0.
Maricopa county law enforcement feed
Old 10-28-2009, 02:39 AM
cellphone's Avatar
Here is what I have so far:
28xxxxx Phoenix PD Portable
29xxxxx Phoenix PD Mobile
3xxxxxx Mesa Radios
702xxxx Light Rail Radios
709xxx Buckeye Consoles
709xxxx Buckeye Radios
713xxxx El Mirage Radios
725xxx Peoria Consoles
725xxxx Peoria Radios
737xxx Surprise Consoles
737xxxx Surprise Radios
847xxx Tempe Consoles
847xxxx Tempe Radios
Anyone have anything to add?
