Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arizona Radio Discussion Forum
Arizona Radio Discussion Forum - Forum for discussing Radio Information in the State of Arizona.
Old 07-22-2014, 9:53 AM
Default Off the wall PL/DPL tones?
This question is a bit off the wall as I would imagine not many folks listen to the radio system in question (if any) so here it goes. Does anyone have the PL/DPL tones for S.A.F.E. Management that provides security at University of Phoenix Stadium? I found their license in the FCC data base so I have the frequencies and possible channel assignments.
Richard Gaun
KG7ETW
Sun City, Arizona
Old 07-22-2014, 9:55 AM
krokus's Avatar
Did you check the database? It has that info, more often than not.
Sent via Tapatalk
Old 07-22-2014, 1:26 PM
Sent via Tapatalk
There is nothing listed in the data base for Stadium Security. Southwest Ambulance uses their "events" Frequency and the PD coverage uses G Deck TGs. Security is on Business Band thus the need for the PL/DPL.
Richard Gaun
KG7ETW
Sun City, Arizona
Old 07-22-2014, 1:59 PM
ko6jw_2's Avatar
Does your scanner have a PL search function? Listen to both the input and output frequencies. Some systems have a different tone for accessing a repeater and the repeater has a separate PL for decode.
Old 07-22-2014, 5:28 PM
What is the emission designator for their frequencies? IIRC, having checked the listings in the SWFD-10 for the stadium, I heard MotoTrbo digital noise. CTCSS/DCS isn't used in MotoTrbo.
There's a lot of MotoTrbo in the 451-470 MHz as well as the 935-940 MHz business/industrial bands. The only analog FM activity in 935-940 MHz that I've heard is SoCal Edison's trunked system, which has a site on the White Tank Mtns.
Old 07-23-2014, 2:07 AM
I do not believe they are on a trunking system. Here are the frequencies listed on the license;
461.95000
466.95000
462.02500
464.32500
464.37500
467.02500
469.32500
469.37500
469.67500
469.80000
469.82500
I have programed these in the scanner with the PL Search active.
Richard Gaun
KG7ETW
Sun City, Arizona
Old 07-23-2014, 6:22 AM
ecps92's Avatar
Correct, according to the FCC, Non-Trunk and Analog (Narrowband)
However only 461.9500 is a Repeater, all others are simplex
461.95000
466.95000
462.02500
464.32500
464.37500
467.02500
469.32500
469.37500
469.67500
469.80000
469.82500
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
