Musical sounding tones on 154.4600
KB7MIB
Peoria, AZ.
Is anyone else in the Northwest Valley, or anywhere else in the Valley for that matter, able to receive the musical sounding tones on 154.4600?
The transmissions are bleeding over onto VTAC-12, 154.4525, on an older scanner (PRO-2020) of mine that doesn't have NFM or CTCSS capability.
I'm just curious as to what the tones are for.
John
Peoria
KB7MIB
Peoria, AZ.
Can SCADA be decoded, or is it proprietary? I'm specifically wondering about the hydrological/meteorological transmissions, like 169.500 that I can hear.
There's some other data transmissions that I'm curious about.
171.9250 (162.2)
452.6000 (225.7)
452.6250
452.8250
460.6000
John
Peoria
ecps92
Taxachusetts
171.9250 (altho generally w/o PL) is another IFLOWS channel
also allocated to the Int'l Boundary and Water Commission over in Texas
171.9250 (162.2)
452.6000 (225.7)
452.6250
452.8250
460.6000
John
Peoria
nd5y
Wichita Falls, TX
It depends on what type of equipment and data format is used.
A long time ago the city water dept. here had a system at all the water towers that used amateur AX.25 packet radio protocol on a simplex UHF channel. I could decode the packets with my TNC but the only thing that was readable was the AX.25 callsign header line and some plain text labels of street names where the water towers were located at the end of hex data.
The packets looked like this:
CTU>CQ/V: <UI>:
AIOII0008000000132000DENVER EST
RTUA>CQ/V: <UI>:
A000884F4E250101801BB60000DC3000000
CTU>CQ/V: <UI>:
BIIII00000000002F1000BURK PRES
CTU>CQ/V: <UI>:
CIIII0000000000178000HOLIDAY PRES
RTUC>CQ/V: <UI>:
C00003BB001007000000000000000000000
CTU>CQ/V: <UI>:
DIIII0000000000155000REILLY EST
RTUD>CQ/V: <UI>:
D00009A0000014000000000000000000000
CTU>CQ/V: <UI>:
EIIII0000000000147000PUCKETT EST
RTUE>CQ/V: <UI>:
E0000A1A000015000000000000000000000
CTU>CQ/V: <UI>:
FIIII000000000013C0009TH ST EST
