Receiving colored vertical bars on 1813.7 MHz, is this an amateur video transmitter?
A AZDon Member Premium Subscriber Joined Feb 10, 2014 Messages 244 Location Flint Michigan Jun 9, 2015 #1 Receiving colored vertical bars on 1813.7 MHz, is this an amateur video transmitter?
T Token Member Joined Jun 18, 2010 Messages 2,382 Location Mojave Desert, California, USA Jun 9, 2015 #2 Assuming AZDon means you are located in AZ, USA, there are no legal ham allocations for 1813.7 MHz, so it seems unlikely what you are seeing would ham related transmission. T!
krokus Member Premium Subscriber Joined Jun 9, 2006 Messages 6,003 Location Southeastern Michigan Jun 9, 2015 #3 A remote video link, and you are in path? Intermod? Sent via Tapatalk
mikewazowski Forums Manager/Global DB Admin Staff member Forums Manager Joined Jun 26, 2001 Messages 13,531 Location Oot and Aboot Jun 9, 2015 #4 Moved to Arizona forum since it's not Amateur Radio related.
A AZDon Member Premium Subscriber Joined Feb 10, 2014 Messages 244 Location Flint Michigan Jun 9, 2015 #5 Note to self and everyone Feds use to hang out here but they were booted off many years ago. Have to wonder if these colored bars are Nanny Cam related.
T techman210 Member Joined May 28, 2011 Messages 389 Location San Bernardino County Jun 10, 2015 #6 Second harmonic? Check out 906.85 Mhz. Perhaps you were seeing a second harmonic. There are no Part 15 frequencies in the 1800 Mhz band.
A AZDon Member Premium Subscriber Joined Feb 10, 2014 Messages 244 Location Flint Michigan Jun 10, 2015 #7 Nanny Cam Thanks, I think you solved this one, thanks.
krokus Member Premium Subscriber Joined Jun 9, 2006 Messages 6,003 Location Southeastern Michigan Jun 10, 2015 #8 AZDon said: Thanks, I think you solved this one, thanks. Click to expand... What did it turn out to be? Sent via Tapatalk
K kma371 QRT Joined Feb 20, 2001 Messages 6,204 Jun 10, 2015 #9 krokus said: What did it turn out to be? Sent via Tapatalk Click to expand... See post 6
krokus Member Premium Subscriber Joined Jun 9, 2006 Messages 6,003 Location Southeastern Michigan Jun 10, 2015 #10 kma371 said: See post 6 Click to expand... Which just says he thinks the question was answered, not what the signal turned out to be. Sent via Tapatalk
A AZDon Member Premium Subscriber Joined Feb 10, 2014 Messages 244 Location Flint Michigan Jun 10, 2015 #11 Colored vertical bars The signal in question is off the air, will continue to look for additional activity.
