KPRC AIRINC Info
ILuvSantaFe
Prescott Valley, AZ
Anyone have an idea of what the AIRINC frequency is being used for the new SKYWEST/UNITED EXPRESS service at KPRC? It's 2 flights per day I tried 129.500 130.175 131.050 and 131.750 No luck so far.
Bill Halpin
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
These are ASRI frequencies licensed KPRC. Give these a try:
129.300 (active license)
129.400 (cancelled license)
131.325 (cancelled license) previously Great Lakes Airlines
131.625 (cancelled license)
Let us know what you find.
ILuvSantaFe
Prescott Valley, AZ
Thanks for all the info about AIRINC Enroute services. But I'm looking for the Pilot to Station Dispatch AIRINC Frequency for SKYWEST/UNITED EXPRESS at KPRC.
Bill Halpin
icemantim8
Colorado
Skywest
Hello Bill,
Not sure if this chart helps. It's for KCOS and has some frequencies related to your question. Plus a few others that might be of interest. I listen to them frequently and they are active:
131.4000 Skywest (air-to-ground)
460.650 141.3 PL Skywest Ops
129.325 American (air-to-ground)
131.925 FedEx (air-to -gound)
130.500 Delta (air-to-ground)
Tim
KC5RYY
nd5y
Wichita Falls, TX
Try searching 128.8-132 and 136-137 MHz and see if you hear them.
Searching FCC licenses for Aviation Spectrum Resources Inc. near that location shows only one active and several cancelled.
https://www.radioreference.com/apps/db/?action=fccProx&lat=34.65114&lon=-112.42156&r=2
Maybe they no longer have a VHF AM voice radio there.
KB7MIB
Peoria, AZ.
Do they have a pilot shop at the airport? Maybe an employee there can help answer your question, or find it for you if you explain you're a scanner listener and what exactly you're looking for.
John
Peoria
scannerhead
Here's a few other freqs that have been associated with Skywest/United Express air to ground.
130.250
130.525
132.000
136.550
As suggested already, searching is probably the best thing to do. Start monitoring about a 1/2 hour before arrival. Contact will probably be closer to 10 mins out. It's possible that station ops may only have a handheld air radio with such a small operation. You may not hear Skywest PRC ops unless you are very close to the airport but should be able to hear the aircraft call while airborne.
Good luck.
clover509
A new license (WRCD886) was issued to Aviation Spectrum Resources, Inc on 9-6 at the airport. Look for ops to be on 131.400. Let me know what you hear.
ILuvSantaFe
Prescott Valley, AZ
After hours of monitoring finally found and can confirm the United Express operations frequency at KPRC. It's 131.400 registered to SkyWest airlines operator of the United Express at KPRC.
scannermike11
Banned
that map is out of date on some of the Freqs 130.8 on the west coast is no longer used and add 131,95
pacific net
