Does anyone have an updated list? Thanx
sorry for my ignorance - what's an FTO?
I've got the scanner set up on B1 with the old SW ch15 (460.62500 - this accurate?) and ProScan running with FTO logger on, will advise on what I capture.
Hopefully I'm doing this right using the FTO search on the scanner correctly. Something I've been meaning to do anyhow.
Sent from my Pixel 2 XL using Tapatalk
It is pretty simple, just set both the A tone and B tone to 0.0. The radio will activate on any decoded tone sets and display the approximate tones. Close enough is good enough for scanners but if you want a complete list of tones used by the various manufacturers see the chart at www.carmachicago.com/profiles/ToneChart.pdf
I've had the tones listed from the Wiki plugged into the scanner and radio, as mentioned previously, Sta 19 and DM are the 9nly 2 I hear them tone out, but I'm out of pocket for much of the valley, let alone the (far for me) west side departments. What's on the Wiki is accurate from my monitoring for 19 and DM
