Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Arkansas Radio Discussion Forum
Arkansas Radio Discussion Forum Forum for discussing Radio Information in the State of Arkansas.
Old 01-11-2013, 2:33 PM
Default bigbuck52
Is there a scanner out there for AWIN? I have a pro 135 which only takes 6 numbers for frequency.
Old 01-14-2013, 9:27 AM
poppafred's Avatar
Anything that will receive P25 digital.
I have a RS Pro 197 and a GRE 500. I listen to AWIN on both of them almost constantly, only break is while sleeping but they are both on and listening even then.
Fred - KK5AA
Pro 2004 -- Pro 91 -- Pro 97 -- Pro 197 -- PSR 500
Icom IC-7000 -- Kenwood TM-V708a -- Yeasu FT-60R
Old 01-20-2013, 9:09 PM
Popafred, thanks for the info- guess I need to cough up the cash and get a new scanner. lol
Old 01-28-2013, 10:33 PM
Has anyone ever tried buying the actual motorola spectra that ASP uses and have the freqs put in? Receiving only of course.. I just figured that would sound a lot better and get a lot better quality. My trunk tracker won't pick up everything that comes across a channel like a real radio will. Practical? Possible?
Old 01-28-2013, 11:44 PM
milf's Avatar
Careful, I CAN hear you!
Send a message via MSN to milf Send a message via Yahoo to milf
To hear a P-25 system using an P-25 radio, the radio MUST affiliate with the system. Any UNATHORIZED radio affiliating on the system will be killed remotely. In other words, it will be made a paperweight with a few keypresses. On the older Type II systems you could get away with using an mobile or HT with TX disabled. Not on an P-25 system. So spending the $3,000.00 or more on an HT or mobile would be a waste. Spend the $100.00 to $500.00 on a digital scanner. Any model from the RS PRO-96/2096 up works fine on almost all the AWIN sites. For the few current 700 MHz sites you will need one of the models in the generation after the 96 series.
Admin & Mod for AR, LA, MS, and TN
Scanology, its the path to monitoring happiness!
Support your local Scanologists!
Old 01-29-2013, 7:41 AM
Default listening
Not necessarily true... You can use a Motorola radio (or any P25 capable for that matter) to scan the frequencies of the voice channels at the sites you are interested in- WITHOUT affiliation of any kind. It just potentially won't track a single talkgroup like being affiliated will allow you to do. There are extensive discussions of this over at the batlabs forums. Just takes some research and programming know-how. You'll have to register at the batlabs forums to find the info- search for "ASTRO25 scanning"
Old 01-29-2013, 7:54 AM
milf's Avatar
And again, you will still pay 3K plus for a radio. If you don't know the ins and outs of programming it, you will just have an expensive brick. If anyone out there has that kind of bucks to toss around, send some my way. I don't need 3K plus... Just a couple of hundred for a new digiscanner, and new HD for the now paperweight laptop LOL!
Old 01-29-2013, 12:03 PM
iamhere300's Avatar
Not anywhere near 3k. You can buy P25, trunking radios for street cost of $1250.00 all day long. That still leaves the dealer a fair profit. Many dealers are selling these.
